I am attempting to set up a trial hub. I believe the is set up properly - I see the correct devices and activities and I can initiate an activity and it works as expected. However, I am constantly getting "Exception in Find_Create_Devices/Enumerator: Conversion from string "" to type 'Integer' is not valid." in the log, with a type of Harmony Hub Error. The other anomaly is the device (in Device Manager) is "Family Room Harmony Hub" but if I build an Event its listed as "Family Room Main Hub1". HS3 has been restarted with no improvement. Ideas?
Issue resolved
Turning on the debug trace messages helped me track down the error - sorry I didn't think of it myself. I added an Arduino recently - supposedly DHCP but it wasn't - it was the same ipadder as the hub. Rebuilding the Arduino, rebooting the Hub and reseting the plugin solved the problem.
Thanks for the suggestion.
Originally posted by GPrade View PostTurning on the debug trace messages helped me track down the error - sorry I didn't think of it myself. I added an Arduino recently - supposedly DHCP but it wasn't - it was the same ipadder as the hub. Rebuilding the Arduino, rebooting the Hub and reseting the plugin solved the problem.
Thanks for the suggestion.Regards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO latest HS4 BETA on a Raspberry
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
