Not detecting devices or activities on linux
Please see this thread for the solution. https://board.homeseer.com/showthrea...id=8&styleid=1Last edited by Rien du Pre; April 23, 2017, 11:32 AM.
No connection to Harmony Hub
I have the same problem.
Cannot find any device.
Using linux debian Jessie 8.7
Current Date/Time: 21/04/2017 10:52:52
HomeSeer Version: HS3 Standard Edition 3.0.0.297
Linux version: Linux raspberrypi 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 15 Hours 24 Minutes 44 Seconds
IP Address: 192.168.1.xxx
Number of Devices: 217
Number of Events: 55
Available Threads: 399
Enabled Plug-Ins
3.0.0.32: EasyTrigger
3.6.5.0: Harmony Hub
3.0.0.68: HSTouch Server
30.0.0.34: RFXCOM
3.0.1.87: Z-Wave
You are running on an ARM processor, so using harmonyhubcontrol_linux_arm.exe.
This isn't the one I recompiled I am afraid; it was the one for x86 processor.
What version of Linux are you running?
No activities or devices
Devices and activities do not show up when scanning. Log info is:
Plugin: Harmony Hub Get Activities ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux_arm.exe', CommandLine='hunter.r.39@rjhunters.com <my password here> 192.168.1.2 list_activities_raw', CurrentDirectory='', Native error= Cannot find the specified file-
On a ZS2
Plugin version 3.6.5.0
Current version is: HS3 ZEE S2 Edition 3.0.0.313
Hub is working perfectly.
Hub and Alexa are working perfectly
IP, login and password are correct (pinged, retyped several times) (I will set the IP address to static later in my router - no need to remind me that DHCP may issue another address.)
Permission given...have attached to this post as a ZIP.
Please let me know how you get on, and please make sure you set the executable permissions correctly:
Backup current file: mv /usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe /usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe.orig
File goes in: /usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe
Permissions Command: chmod 755 /usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe
ChrisAttached Files
Hi everyone,
I have this compiled on jessie/sid (Ubuntu 14.04.1 LTS (GNU/Linux 3.16.0-031600-generic i686)), which is the latest OS that stock SEL units are shipped with (as far as i am aware).
All working as expected (as far as i have tested, which is so far just scanning devices and activities, of which all appear!).
I am waiting for Rien to confirm happy for me to share. I will send over to you when I can with instructions - I would be interested to hear peoples experiences.
Chris
Yes please. I will of course treat your code in confidence (not that I would understand it anyway - I am a sys admin, not a coder) - happy to compile for the current SEL (Ubuntu 14.04) and supply to those in need
I can share the source with you, so it can be complied on any platform you like.
I'm not familiar with Linux and this has been a struggle for me every time a compiling issue arises
Also, listing versions doesn't display the one needed, which also points towards the lack of 'GLIBCXX_3.4.21' being the problem:
/usr/lib/i386-linux-gnu# strings libstdc++.so.6 | grep GLIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_DEBUG_MESSAGE_LENGTH
Edit: Upgrading libstdc++6 to 6.2.0-3ubuntu11~14.04 did not help. I now get GLIBCXX_3.4.21, however get the following error instead:
usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe: relocation error: /usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe: symbol _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEC1Ev, version GLIBCXX_3.4.21 not defined in file libstdc++.so.6 with link time reference
The app seems to have been complied with a GCC version that isn't compatible with the versions installed on the factory SEL units.Last edited by chrisgreene11; March 28, 2017, 02:38 PM.
So, from a standard build SEL (Ubuntu 14.04 LTS), fully updated using apt, i get the following error when setting the application file 'harmonyhubcontrol_linux.exe' to 755 and just running (with and without command line options):
./harmonyhubcontrol_linux.exe: /usr/lib/i386-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./harmonyhubcontrol_linux.exe)
This has to be it i guess - if it cant run via CLI, then it probably isn't going to work via the main interface.
Rien, do you have any thoughts on this?
What works, exactly?
My permissions are already set to 755 on that file and pressing Create HS Activity devices and Create HS hub devices creates one Harmony Hub device, labelled as Powered Off (it isnt) but still doesn't display any of my activities or devices when trying to scan - still the same error. Am also seeing the following in the log since creating that device:
Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Same here, can't get devices created. Pi3, HS3 Standard.
From log:Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
To get devices and activities in the plugin I needed to change permissions on harmonyhubcontrol_linux_arm.exe from 0644 to 0755.
(in usr/local/HomeSeer/bin)
Edit: It works if If I first "press" Create HS Activity device(s) and then "press" Create HS Hub device(s)Last edited by lunkan; March 19, 2017, 02:38 PM.
Did this ever get resolved? I am having the same issue on an SEL.
I'm experiencing the same issue.
HS3 Standard on Raspberry Pi2 (Ubuntu Mate)
See the logging below:
Feb-22 8:01:51 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Feb-22 7:56:51 PM Plug-In Finished initializing plug-in Harmony Hub
Feb-22 7:56:50 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:51370
Feb-22 7:56:48 PM Plug-In Interface Harmony Hub is running as a trial, 28 days remaining.
Feb-22 7:56:36 PM Info Plugin Harmony Hub with instance: has disconnected
Feb-22 7:56:36 PM Plug-In Shutting down Plug-In: Harmony Hub
Feb-22 7:55:44 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Feb-22 7:54:44 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Originally posted by DeLicious View PostI was trying this out with my hub, but it's not detecting devices or activities.
All I get in the log is:
Feb-17 10:10:37 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
Feb-17 10:10:35 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
I confirmed that I had it set up with the right username and password, and I double-checked the IP address several times, including pinging it and making sure it was responsive. Is there anything else I can try in order to get my devices and activities sync'd?
I need more logging to investigate.
