This plugin has been working flawlessly for me for the last year or so since I discovered it, but in the last ~2 weeks, it almost never works. Attempting to discover devices/activities (as a troubleshooting step) works ~25% of the time (mostly it says "no devices found") but once in a while it will work.
Trying to execute an activity rarely does anything (though once in a while it does), and with debug logging on, I sometimes see this:
"Plugin: Harmony Hub Test Get Active Activity output for:Hub1: HARMONY COMMUNICATION LOGIN : FAILURE ERROR : connectToHarmony : Unable to connect to specified IP Address on specified Port -"
(Unrelated note: something like this should be normal logging, not hidden under debug, please!)
I have the IP address correct in the configuration (otherwise it wouldn't work "sometimes", and is a DHCP allocated address in my router) and port isn't a field to specify.
Help, please!
Help, please!
