Originally posted by janjoh
View Post
Missing activities and International characters does not decode propertly
rien,
same problem here,
activities are not being populated anymore, for at least one of my hubs (the most important one). I also tried duplicating this hub as hub 5 and did a rescan.
only activity that is detected is the poweroff
Hub 5 Devices:
- DVR Cams
- XBMC Mediacenter
- Tv Philips
- AV-ontvanger Pioneer
- Klimaatregeling Fujitsu
- XBOX360
- Sony BluRay Speler
- Homeseer HS3
- Horizon DVR
Hub 5 Activities:
- PowerOff
but the activities that should populate are;
Hub 1 Activities:
- PowerOff
- Radio
- Internet Radio
- Bluetooth
- Front HDMI AV
- DSaudio
- XBMC Kijken
- MiraCast
- Smart-tv kijken
- TV Kijken
- MediaBluRay
- Xbox 360 spelen
- TV HDMI Side
and the added activity which wont show up is "TV kijken via TV"
I also added a nest as device, which is not detected, but i can imagine that this wont show because also hues are not listed.
regards
BartRegards Bart
Win7 64Bit on Intel NUCI7 with SSD
HSPRO 3.
Devices; 1370 Events; 691
Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
I'm also having problems with some of the activities and devices not showing up.
I have 3 hubs. Not one of them have all activities shown and only one of them shows all the devices.
One room is missing the device "Amazon Fire Tv" and the activity "Watch Fire Tv" but yet it shows "Watch Local Tv". I did try to remove spaces without luck and I see others show up with spaces and caps so I don't see a pattern why some show up and some don't.
But not one of the 3 hubs show everything like it should. If you got any other tips or tricks as to why that would happen I'm open for ideas to try.
Originally posted by integlikewhoa View PostI'm also having problems with some of the activities and devices not showing up.
Go to the HomeSeer root folder on your system and execute the following command:
bin\Harmonyhub\HArmonyHubControl list_activities
And sent me the output
This output is used in the plugin, if your activities are not listed the plugin won't show them too.
Thanks,Last edited by Rien du Pre; December 4, 2016, 03:31 AM.Regards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO latest HS4 BETA on a Raspberry
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Rien du Pre View PostCan you and Bart do the following.
Go to the root folder on your system and execute the following command:
Wooow.
I did a firmware update on one of my hubs and now I have similar issues
Can all off you who are facing this issue with missing activities respond with your hub firmware version?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Rien,
I am also on 4.12.36...
Bart
Verzonden vanaf mijn iPhone met TapatalkRegards Bart
HSPRO 3.
No update in the offical api documentation? Or are the activities not covered?
HSPRO 3.
