Working with HC-66
  • Working with HC-66
    Hello,
    I've got a GW-SL1 that's controlling the mid-level HC-66. Do you think the plug-in will work with it?
    Sebastien
    The plugin requires a serial connection to the HTD switch/controller. If you can install the drivers and get a com port mapped via the GW and it appears to the Homeseer box as a serial port, then you may have a chance. I have looked at the Mid-Level API in the past, but it's been several years. I do think they are quite similar, so there may be a chance. You can give it a shot and let me know if you have any luck. Right now I'm out of the country but will return in the coming weeks. Once I do, I can try to dig up the MLC API documents and see if they would fit in the same API as the Lync.
      Thanks for your reply! :-)
      I'm willing to give it a try. I will try to have a look on this in the next days.
