Hello, I'm using the plugin to control a Global Cache GC-100-06 device and, in general, this has been working pretty well.
Over the last week or so, however, the plugin is malfunctioning intermittently. When this happens, the logs are reporting a message of "Incomplete IR Event" from the plugin. When this happens all IR commands fail to function. I can still access the WebGUI of the Global Cache device when this happens, and power cycling the Global Cache doesn't resolve things either, the single point of unity here seems to be the plugin itself.
In every case, I can just disable/re-enable the plugin and it will work again. This is happening with increasing frequency, however, as I'm now resetting the plugin almost every day to clear this condition.
I have just enabled the enhanced logging for the plugin so I'll review that standalone log file if/when the issue presents itself, but wanted to ask if this was something known or if anyone had any suggestions.
This is HS4 on Linux Ubuntu 20.x
thank you,
Adam
thank you,
Adam
