Am I right in understanding that a Broadlink unit (also the Broadlink Mini 4?) will connect to the raspberry/HS4 by using the MCSMQTT plugin?
USBUIRT on HS4/Pi
However, the HS4 I am using does not give access to this plugin. Perhaps it does run on Windows HS4?
My UsbUirt is presently working on a Usb to IP remote connection (VirtualHere and an old RasPi) but I'm not happy with that as it's a bit flaky. I was looking at different Usb to IP systems, but the Broadlink is much cheaper than those.
Can anybody confirm if the Broadlink can replicate the two way "IR from remote control triggers HS4 event" and "HS4 event sends out IR to control AV amp etc" functionality ?Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
The Broadlink RM4, and I believe all Broadlink models, are mode-based so they can be either sending IR or receiving IR, but not both at the same time. The software I developed for the mcsMQTT plugin was done based upon it's design use-case where the IR receive was done for the purpose of learning an IR code and not for the purpose of providing notification that an IR code was detected. The Broadlink internal firmware establishes a time window for detecting a code while learning. Since the time window is fixed it is not possible to setup the device for a 100% detection interval. It could reenter learning mode after timeout, but then there would be times that it could miss a IR signal.
Tasmota firmware supports both IR Receive and IR Send and can be installed in a device such as YTF IR Bridge - Tasmota. I have no specific experience with the YTF. What I have done is installed Tasmota in a generic ESP8266 as described in Section 17.23 of http://mcsSprinklers.com/mcsMQTT.pdf. My experience was that it worked fine for sending IR to control equipment and providing feedback that an IR code was sent. What it would not do is simultaneously do both. I suspect is by design since it would be receiving the same code it was sending.
What I did was separate the packaging into a separate IR receive function and IR send function so I could receive IR at a central location where my pickup was and send IR from a more advantageous blaster location. Since the two are independent devices there was no possibility of contention.
I just uploaded v4.0.0.4 of my plugin to the updater. It now supports sending IR codes via a USBUirt on Windows. Unfortunately it will need extra coding to get it to work on Linux and I hope to release that in the next version soon. Receiving IR codes from a USBUirt will be in another version sometime after that.
- Likes 2
Guest
Originally posted by drule View PostI just uploaded v4.0.0.4 of my plugin to the updater. It now supports sending IR codes via a USBUirt on Windows. Unfortunately it will need extra coding to get it to work on Linux and I hope to release that in the next version soon. Receiving IR codes from a USBUirt will be in another version sometime after that.
Guest
Hi drule, finally migrated to HS4; trying to get the plugin to work with my USB-UIRT but getting the following :
Any idea what could be wrong?
12/6/2022 10:09:02 PM
HomeSeer
Warning
I/O interface IR Plugin is down, executable is not running, restarting ...
12/6/2022 10:08:32 PM
HomeSeer
Starting Plug-In
Plugin IR Plugin started successfully in 341 milliseconds
IR Plugin
Info
Found UsbUirt windows device
IR Plugin
Info
Loaded 0 IR senders.
IR Plugin
Info
Loaded 0 IR receivers
IR Plugin
Info
Loaded 0 IR codes
IR Plugin
Info
Starting IR Plugin, version 4.0.0.6
HomeSeer
Starting Plug-In
Initializing plugin IR Plugin ...
HomeSeer
Starting Plug-In
IR Plugin loaded in 15103 milliseconds
12/6/2022 10:08:17 PM
HomeSeer
Info
Plugin drhsIR with instance IR Plugin has connected. IP:127.0.0.1:54851
HomeSeer
Warning
12/6/2022 10:07:47 PM
HomeSeer
Starting Plug-In
Plugin IR Plugin started successfully in 352 milliseconds
IR Plugin
Info
IR Plugin
Info
IR Plugin
Info
IR Plugin
Info
Loaded 0 IR codes
IR Plugin
Info
