I'm struggling to successfully send a command to the Serial Port of a GC-100-12. The command string I need to send is: \x02\x50\x4F\x4E\x03, which I have validated using the iTest.exe application. I'm trying to configure an Event to send the command, and I'm not sure what value to put in the LED field. I've used a value of 1:1 since the serial port is listed on Module 1 on the device. I've configured the Device in the IR Plugin to point to port 4999. Is there something else that I'm missing?
Thank you, Mike
Thank you, Mike
