I need support on this issue. Anyone using two Irtrans ethernet Lan Poe,s?
I probably do something wrong , but what?.</OConfig <O[LIST]
2 IRTrans PoE
1 IRTrans 2K
1 IRTrans 4K
I have put it all toghether:
Installed the two POE.s one in the living room and one in the Cinema, they got fixed IP and bus id zero and one, both with Device ID xero.
Installed the IrtransLan and IrtransGui..
The Homeseer plugin( I have a error message * on this one after trying to download and install again. (Can't find any reference in Homeseer directory to IRtrans other than the new one installed)
Defined all my audio/video etc. Into Homesser. At first only defined 1 zone (Default ) in Homeseer, onlys one of the POEs worked. Added two Zones 2 and 3, 2 is working 3 is not.
I have runned the learning prosess for every remote. And at the end of the day it works, however only one of the POE works for learning at a time. (Seems to be the First in IRTrans Diagnostic list Bus 0)
If I screw around the with the Mode setting in the GUI it may shift to the second one and vica versa, then the other POe is working and can be used for learning, the other do not work.
If I use the send command function in IRTransGui, defining _hs-remote, I can send commands to both POEs.
In the Device Set mode av tried different settings, for BUS 0 and 1. At the moment both 0.0 and 1.0 have the same setting - relay set on all devices. Both have Ethernet Tranceiver address 0
See attached system info.
1 IRTrans 2K
1 IRTrans 4K
