Presently I have Ocelot driven IR control in one room of our house, but have wanted to expand to two other zones/rooms as well. Is it possible to get an IRTrans/Ethernet and use it with your plugin for one of these other rooms first (without changing the Ocelot setup in the first room), then order another unit to replace the Ocelot setup already working in the first room? It's a question of time available and WAF to keep the first room "in production".
I wasn't clear if HS would support two IR interfaces live at the same time, or if I'd have to make an initial cutover entirely from Ocelot & Adiocelot plugin to the IRtrans ethernet unit and plugin.
Cheers,
Scott
Cheers,
Scott
