IRTrans Testing
Hi Brian,
Thanks for the quick reply!
The only times I have seen it iterate through the database is when it is starting up or there is an IR code that has been added/changed.
It looks like what is happening is that it is looking to see if the codes in the HomeSeer file matches a corresponding entry in the IRTrans.rem file.
If I remember correctly, this is the only times I have seen it iterate like that.
Everything does seem to work well. The only remaining problem I have left is getting my XBOX 360 to work with IRTrans. It seems to be the problem child right now. I am going to tackle it again this weekend and I will let you know what I find out.
Thanks Brian!
Chuck
Hi Brian,
Thanks Brian!
Chuck
