Beginners question
    Beginners question
    hi there , I am looking at the following device:
    http://www.irtrans.de/en/shop/lan.php
    Is this all I need? will this learn the commands from my remotes or do I need something else to plugin to the homeseer server to learn the commands? I can then place this in my lounge (homeseer is in loft) and send ir commands from my homeseer server over cat5 to this device and then to my tv etc .
    is that right ?
    Chris
    I am using an IRTrans unit, although it is the serial instead of the ethernet version. Using the IRTrans plugin (free), I learn IR codes directly into HS.
    You will need a power supply I believe.
    tenholde
    tenholde
