IRTrans - don't see incoming IR signals in HS
    Team
    My IRTrans/HomeSeer plugin can send signals without a problem. Receiving the signals in HomeSeer doesn't seem to work. Is there anything specific I have to configure to see incoming IR signals in HS (log)?
    Because of this the "Match I/R" event trigger doesn't do anything.
    The irserver.ini only contains "lan"
    DJ
    Hi DJ,
    I think the fist thing to verify is that the IRTrans equipment is functioning OK outside of HomeSeer.
    Can you use the IRTrans GUI client to verify that you can send and receive that way?
      I think that your response triggered my IRTrans to work as expected. I now see incoming IR signals in the HS log and the event triggers work fine!
      Don't know what changed..
      DJ
