I am trying to control the 4 external IR output led and I get very strange results.
I have tested one device installed on the following zones in HS2:
zone 120:
In the Diagnostics window of the Irtrans server I got the following:
Send [0] hs2_signals - 1 [30001 - B:0 M:0x1 LED: Default]
The device is working both from the internal and external led of the LAN I/O
zone 121:
The command received by IRTrans is :
Send [0] hs2_signals - 1 [30001 - B:0 M:0x1 LED: External]
In your "IRTrans Installation and Configuration Guide (PDF)" HS2 zone 121 was suppose to be Internal LED only. Anyway this command is working correctly - only the external led are sending commands.)
zone 122: LED: Internal (again, in the guide this is marked as External, but is working correctly - internal works, external no working)
zone 123: LED: All (this is working OK)
zone 124-130: LED: Default (this is working OK)
Now the surprise:
zone 131: Led: 9
zone 132 - 138: Led 10-16
Normally I would need zone 131 to activate the Led 1, zone 132 activate led 2, etc.
I have also tested :
139 - 198: Led: Default (all are working fine)
This is strange. Maybe the Led 1-8 are is some other zones ?
Using GUIclient I can control every external zone (from 1 to 4) separately without any problem (select from the Led Select drop down list All/Default/External/1/2/3 or 4 and all are working as they should - all together or separately, as required).
I am using a registered version of Homeseer (Standard Edition 2.5.0.1) and the Irtrans plugin (1.2.15.0) downloaded using Homeseer updater.
Any help would be highly appreciated,
zone 120:
zone 121:
Now the surprise:
zone 131: Led: 9
