Ir learning / receiving
    Hello and thank you in advance for any help.
    I am having trouble with my IRTrans receiver, below is a list of four IR codes learnt through the webpage interface. The codes are stored in the hs2_signals.rem file and no errors are reported in the hs log for the learning process.
    When I try and receive the codes the log shows
    For device 0
    IRReceived method called: unit 0, remote , command
    Remote is not hs2_signals, so will be ignored.
    For Device 1
    IRReceived method called: unit 0, remote hs2_signals, command 1
    For Device 2
    IRReceived method called: unit 0, remote hs2_signals, command 2
    For Device 3
    IRReceived method called: unit 0, remote hs2_signals, command 3
    And
    For testing I have removed all .rem files except hs2_signals.rem
    Any ideas?
    Cheers
    [REMOTE]
    [NAME]hs2_signals
    [TIMING]
    [0][N]5[1]176 272[2]416 272[3]184 600[4]176 760[5]184 1904[RC]1[RP]0[FREQ]38
    [1][N]3[1]4528 4472[2]616 480[3]624 1632[RC]2[FL]109[FREQ]38[SB][RS]
    [2][N]3[1]8504 4200[2]576 504[3]576 1544[RC]2[FL]89[FREQ]38[SB][RS]
    [3][N]5[1]9024 4472[2]560 568[3]568 1664[4]8992 2216[5]568 44664[RC]1[RP]0[FREQ]38[SB]
    [COMMANDS]
    [0][T]0[D]1432304330
    [1][T]1[D]S111000001110000010011001011001100
    [2][T]2[D]S101001010101101001011000101001110
    [3][T]3[D]S10100001000011001101000000001111320
    Not really sure what you're asking...
    It looks like the last 3 codes were recognized by HS, but there was no match on the first one.
    You don't need to remove any files...
      [quote=YoYo;1004815]
