HomeSeer zones 121 & 122 description reversed in documentation.
    I just installed a new IRTrans WiFi unit and in the course of installing it, I found that when IR commands specify Zone 121, they are directed to the External LEDs and when Zone 122 is specified, the command uses the internal LED. This is reversed from the documentation.
    I discovered this using the IRTrans Diagnostics window so when I had zone 122 selected in the HS Infrared Signal Configuration, this was the Diagnostics output:
    Send [2] hs2_signals - 4 [4003ffff - B:0 M:0xffff LED: Internal]
    I love the IRTrans & this plugin -- everything is functioning for me - I just wanted to pass along a heads up about this anomaly I ran into.
