Error hs2_signals not found - Solved!
    Hi,
    I moved my IRTrans from Windows XP to Windows 7 64 bit. I followed the instructions to the dot but I'm having issues with it. Getting an error GetDeviceData failed for location 0: IR Error: Specified Remote Control [hs2_signals] not found.
    Thanks for your help,
    Aldo
    Hi Aldo,
    Looks like the "hs2_signals.rem" remote file is either missing or in the wrong location...
    It should be present in the same folder as the rest of the IRTrans remotes.
    For a 64-bit install, it would usually be:
    "C:\Program Files\IRTrans\remotes"
    Of course, that's assuming you've installed the 64-bit version of the IRTrans software...
      Thank you, you are correct, I just came out with the same conclusion right now, I was look into the IRTrans documentation and they mentioned moving these files on a different location in Windows 7.
      Thank you for your help,
      Aldo
