Event not triggered?
    Team,
    When receiving an IR signal, the event that's supposed to be triggered is not executed.
    IRTrans.log
    22:56:19.591 : OK : CheckTrigger10 called with remote=humax-dvd, code=8
    22:56:19.607 : OK :   CheckTrigger10 found 1 potential triggers.
    22:56:19.607 : OK :   evRef=8886, UID=3911, SysId=10, Bus=255, Device=9999, Remote=humax-dvd, code=8
    22:56:19.607 : OK :   CheckTrigger10: trigger fired for event 'IR LAMP 8 toggle TESSST'
    22:56:19.607 : OK :
    22:56:19.607 : OK : IRTransTrigger1.CheckTrigger15: called with remote=humax-dvd, code=8
    22:56:19.607 : OK : IRTransTrigger1.CheckTrigger15: Found 0 potential triggers.
    22:56:19.607 : OK : IR Received:
                                      Bus:            0
                                      Device:         0
                                      Remote:         humax-dvd
                                      Command:        8
                                      Command Number: 0
                                      Data:           S1000000000010000001000
                                      Address:        0
    22:56:19.607 : OK :
    22:56:19.607 : OK : CheckTrigger10 called with remote=humax-dvd, code=8
    22:56:19.622 : OK :
    22:56:19.622 : OK : IRTransTrigger1.CheckTrigger15: called with remote=humax-dvd, code=8
    22:56:19.622 : OK : IRTransTrigger1.CheckTrigger15: Found 0 potential triggers.
    Executing the event manually works great.
    Here's the event
    Any idea?
    Hmmmm, initially, it looks from the log that everything on the IRTrans side of things is working, in that it does show a matched trigger.
    To test, perhaps just have an action that speaks something, or flip a virtual device on, i.e. something with no other dependencies to see if that works.
    BTw, in the IRTrans log, CheckTrigger10 should match on IR code received, CheckTrigger15 is looking for a sequence of received codes and should fail...
    Do you have other IRTrans triggers that are working?
