jvESS Script Updates
This topic is closed.
This is a sticky topic.
  • jvESS Script Updates
    This thread will contain only the must current updates to the jvESS script. Please put your questions/bugs in new threads. Thanks.
    Beta Version .08 of jvESS_Config.aspx
    - Fixed a problem when HS devices are created. Please delete and re-add you HS devices for jvESS.
    Beta Version .06 of jvESS_Functions.vben script
    The attached zip file contains an installer that should put the programs and images in the right files. Please let me know if you have any issues.
    Updated 9/24/08
    James
    Running HS 3 on Win10 .
    Here are some of the script commands available that for the jvESS Script
    jvESS Public Functions
    jvESS_On(ESS_Zone):
    The following code turns on module 1: hs.runex("jvESS_Functions.vben","jvESS_On","1")
    jvESS_Off(ESS_Zone)
    The following code turns off module 1:hs.runex("jvESS_Functions.vben","jvESS_Off","1")
    jvESS_VolUp(ESS_Zone)
    The following code turns module 1 volume level 1 up by 1:
              hs.runex("jvESS_Functions.vben","jvESS_VolUp","1")
    The following code turns module 1 volume level 1 Downby 1:
                           hs.runex("jvESS_Functions.vben","jvESS_VolDown","1")
    jvESS_AmpA(ESS_Zone)
    The following code sets module 1 to Amp A: hs.runex("jvESS_Functions.vben","jvESS_AmpA","1")
    jvESS_AmpB(ESS_Zone)
    The following code sets module 1 to Amp B: hs.runex("jvESS_Functions.vben","jvESS_AmpB","1")
    jvESS_VolSet("Module|VolumeLevel")
    The following code sets module 1 to volume level 6: hs.runex("jvESS_Functions.vben", "1|6")
    James
