Event options not showing
  • Event options not showing
    James I followed your instruction installing it w/winrar and I just wanted to know if the file are in there correct place. If so, I still dont have the options
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    And this file
    Hector
    Win.2003 OS, HS3
      You actually need the jvESS_Functions.vben in the scripts directory. Also you will need to delete re-create your hs devices. Can you post a shot of your jvESS_Config page?
      I will try to get the readme.txt to include exact files and directories. Thanx.
      James
      Running HS 3 on Win10 .
        Are you saying that I dont have the jvESS.vben in the script dorectory? I did delete devices and I then went to the configpage and updated and it created the devices again. I also rebooted PC and no joy. Here a screen shot of config page.
        Hector
        Win.2003 OS, HS3
          Now I have jvESS_functions.vb and jvESS.vben in the same script folder. I deleted device, I then went to the config page I did an update, it created the devices again. I then restarted HS, went to my event page and tried creating an event to see jvESS options (under action tab) but there was no change.
          Hector
          Win.2003 OS, HS3
            Your config page shows that the most current versions aren't being executed. The apsx should show .06.
            James
              what can I do, so it can execute?
              Hector
              Win.2003 OS, HS3
                I will post a zip file with an installer later today. My guess is that others will also have a problem. Although, once it is in the HS updater is shouldn't be a problem, it looks like I still have ways to go before the script will be ready for the HS updater.
                James
                  Here is an installer for the jvESS Script. I tested it and it seems to do what I need. Let me know your results.
                  I am having trouble uploading. Still working on it. Anyone that wants this version please e-mail me at jvESS at renefe dot com
                  James
                    Well my ESS was supposed to be here today, but when I checked the fdx site it now shows tomorrow, so I will be able to help troubleshoot once it gets here
                    Over The Hill
                    What Hill?
                    Where?
                    When?
                    I Don't Remember Any Hill
                    Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
                      I just installed program w/installer, procedures went well, it created Jvess folder and BIN folder and also placed Jvess functions file in script folder, but now I have this Error:
                      9/22/2008 2:18:24 PM - Error - Reading script: C:\Program Files\HomeSeer 2\scripts\jvESS_Functions.vben Script does not appear to be encrypted properly.
                      9/22/2008 2:18:24 PM - Error - Loading script jvESS_Functions.vben :File not found: jvESS_Functions.vben
                      It also created Device in status page w/ no icons it has the unknown black dot.
                      Hector
                      Win.2003 OS, HS3
                        Config page says jvess ver .6 so it seems that is the latest ver. I thing that I noticed is, if you place a zero in the com. port prompt and hit connect it will say that its connected...
                        Hector
                        Win.2003 OS, HS3
                          Hector, I am just guessing here, but since James had sent you an unencrypted version before, I would delete all the files and try to reinstall with the installer
                          Jack
                          Over The Hill
                          What Hill?
                          Where?
                          When?
                            I did that before installing, the only file I did not delete because I forgot was the images file.. I verified if I had any other old file but all came from the installer.... now it does not work at all, (control wise).
                            Hector
                            Win.2003 OS, HS3
                              Its saying that it does not see the funtion.vben file but its there, cant figure it out.
                              Hector
                              Win.2003 OS, HS3
