Well I plugged it in and set the comm port and this is the log results. The config page is showing the devices, I need to setup HC but I thought I would paste before I lose it
9/23/2008 2:08:30 PM - jvESS_Functions.vb - Connect() to port = 12
9/23/2008 2:08:30 PM - jvESS_Functions.vb - Sending to port = [F]
9/23/2008 2:08:31 PM - jvESS_Functions.vb - Sending to port = [l]
9/23/2008 2:08:32 PM - jvESS_Functions.vb - Sending to port = [c]
9/23/2008 2:08:32 PM - jvESS_Functions.vb - Sending to port = [F]
9/23/2008 2:08:32 PM - jvESS_Functions.vb - Sending to port = [l]
9/23/2008 2:08:32 PM - jvESS_Functions.vb - Sending to port = [0041]
9/23/2008 2:08:33 PM - jvESS_Functions.vb - Sending to port = [1136]
9/23/2008 2:08:34 PM - jvESS_Functions.vb - Sending to port = [1132]
9/23/2008 2:08:35 PM - jvESS_Functions.vb - Sending to port = [1036]
9/23/2008 2:08:36 PM - jvESS_Functions.vb - Sending to port = [1032]
9/23/2008 2:08:37 PM - jvESS_Functions.vb - Sending to port = [0936]
9/23/2008 2:08:38 PM - jvESS_Functions.vb - Sending to port = [0932]
9/23/2008 2:08:39 PM - jvESS_Functions.vb - Sending to port = [0836]
9/23/2008 2:08:41 PM - jvESS_Functions.vb - Sending to port = [0832]
9/23/2008 2:08:42 PM - jvESS_Functions.vb - Sending to port = [0736]
9/23/2008 2:08:43 PM - jvESS_Functions.vb - Sending to port = [0732]
9/23/2008 2:08:44 PM - Info - Event Trigger "camstat stats"
9/23/2008 2:08:44 PM - Info - Running script in background: camtest.txt
9/23/2008 2:08:44 PM - Info - Event Trigger "Outdoor weather"
9/23/2008 2:08:44 PM - Info - Running script and waiting: weatheroutside.txt
9/23/2008 2:08:44 PM - jvESS_Functions.vb - Sending to port = [0636]
9/23/2008 2:08:44 PM - Info - Running script in background: wind_dir_compass_point.txt
9/23/2008 2:08:44 PM - Info - Event Trigger "Fan Control Threshold (W)"
9/23/2008 2:08:44 PM - Info - Device: Weather H/C Threshold (Z11) ON
9/23/2008 2:08:45 PM - jvESS_Functions.vb - Sending to port = [0632]
9/23/2008 2:08:46 PM - jvESS_Functions.vb - Sending to port = [0536]
9/23/2008 2:08:47 PM - jvESS_Functions.vb - Sending to port = [0532]
9/23/2008 2:08:48 PM - jvESS_Functions.vb - Sending to port = [0436]
9/23/2008 2:08:49 PM - jvESS_Functions.vb - Sending to port = [0432]
9/23/2008 2:08:50 PM - jvESS_Functions.vb - Sending to port = [0336]
9/23/2008 2:08:51 PM - jvESS_Functions.vb - Sending to port = [0332]
9/23/2008 2:08:52 PM - jvESS_Functions.vb - Sending to port = [0236]
9/23/2008 2:08:53 PM - jvESS_Functions.vb - Sending to port = [0232]
9/23/2008 2:08:54 PM - jvESS_Functions.vb - Sending to port = [0136]
9/23/2008 2:08:55 PM - MOTION - <<<<<<<< No Motion with Outside Motion West Front - Motion Detected (00:01)
9/23/2008 2:08:55 PM - MOTION - <<<<<<<< No Motion with Inside Motion Living Room - Motion Detected (00:01)
9/23/2008 2:08:55 PM - jvESS_Functions.vb - Sending to port = [0132]
9/23/2008 2:08:56 PM - jvESS_Config.aspx. - Error = An unexpected error occured in the AddModule_row function/subroutine: [System.NullReferenceException: Object reference not set to an instance of an object. at jvESS_Config.getDeviceNameType(String pDevice) in D:\Program Files\HomeSeer 2\html\jvess\jvESS_Config.aspx.vb:line 714 at jvESS_Config.AddModuleRow(Int32 pModuleNumber) in D:\Program Files\HomeSeer 2\html\jvess\jvESS_Config.aspx.vb:line 389]
9/23/2008 2:08:57 PM - jvESS_Config.aspx. - Error = An unexpected error occured in the AddModule_row function/subroutine: [System.NullReferenceException: Object reference not set to an instance of an object. at jvESS_Config.getDeviceNameType(String pDevice) in D:\Program Files\HomeSeer 2\html\jvess\jvESS_Config.aspx.vb:line 714 at jvESS_Config.AddModuleRow(Int32 pModuleNumber) in D:\Program Files\HomeSeer 2\html\jvess\jvESS_Config.aspx.vb:line 389]
9/23/2008 2:08:57 PM - Error - Web Server Error 404, cannot serve file: D:\Program Files\HomeSeer 2\html/images/jvESS/StatusOff.gif
I'll go play some more and report
Jack
Jack
