Problems with ver 2.2.0.15
  • lpitman
    Murphy, try this version 2.2.0.16
    Attached below...
    1.) Exit HomeSeer
    2.) Copy "hspi_lrpSpeak.dll" into your HomeSeer directory
    3.) Re-start HomeSeer.
    Let me know how it works out.
  • lpitman
    Testing right now, will post later this evening.
  • Czechmarty
    Any luck Larry? Please post the new dll and I'll try it.
    Marty
  • Czechmarty
    That would be relieve. I really want this to work.
    Marty
  • lpitman
    Sounds like I zipped up a incorrect version for the updater, I will check into this tonight. Based on a couple comments you made, it sounds like items corrected in ver 2.2.0.15 are not there, I can only assume I screwed up while packaging everything in the zip file.
  • Czechmarty
    Larry,
    I did some more testing and still no go. Most of the times the plugin would shut down because the "AB8SSGetStatus()...sent * but received *8400'
    " error. When it actually initialize OK, The [Loc All] would work, but single (or more) speaker(s) wouldn't.
    I tried 3 different cables with no difference.
    Also:
    [1] When HS shut down, the plugin would turn all speakers OFF, but when restarted the plugin won't turn them back on.
    [2] Looking into your log - why the plugin delete devices during shutdown and recreate them during startup?
    Attached are 3 logs from my testing and the ini file.
    I can probably dig my COM port monitor program and monitor the port if it would be any help to you.
    Did you ever try the pull method instead the event method?
    Marty
  • lpitman
    Please enable debug mode in the ini file located in HS\Config directory. This will give me more info to work with, thanks...
  • Czechmarty
    started a topic Problems with ver 2.2.0.15
    Hello Larry,
    Just installed the plugin from updater, but have some problems:
    [1] When trying to add action "speakers" into action, I have only 7 speakers (missing speaker 1)
    [2] When I set the action I get "lrpSpeak: (lrpSpeak Error 13.) "
    [2] As soon as I change names I get error during startup
    8/18/2008 1:46:41 AM - Info - Interface lrpSpeak is running as a trial, 29 days remaining.
    8/18/2008 1:46:41 AM - lrpSpeak Info - RegisterCallback Completed...
    8/18/2008 1:46:41 AM - Info - Initializing Plug-in: lrpSpeak on COM port 5
    8/18/2008 1:46:41 AM - Database Item - Saving Device Speaker-1
    8/18/2008 1:46:41 AM - Database Item - Saving Device Speaker-2
    8/18/2008 1:46:41 AM - Database Item - Saving Device Speaker-3
    8/18/2008 1:46:41 AM - Database Item - Saving Device Back Porch Speaker
    8/18/2008 1:46:41 AM - Database Item - Saving Device Kitchen Speaker
    8/18/2008 1:46:41 AM - Database Item - Saving Device James Bedroom Speaker
    8/18/2008 1:46:41 AM - Database Item - Saving Device Audrey Bedroom Speaker
    8/18/2008 1:46:41 AM - Database Item - Saving Device Master Bedroom Speaker
    8/18/2008 1:46:41 AM - Database Item - Saving Device Input A/B
    8/18/2008 1:46:42 AM - lrpSpeak Info - ComPort is Initializing....
    8/18/2008 1:46:42 AM - lrpSpeak Info - COM5: Opened successfully.
    8/18/2008 1:46:42 AM - Database Item - Saving Device All Speakers
    8/18/2008 1:46:43 AM - lrpSpeak Error - AB8SSGetStatus()...sent * but received *8400'
    8/18/2008 1:46:43 AM - lrpSpeak Error - InitializeAB8SS()->AB8SSGetStatus()...Failed.
    8/18/2008 1:46:43 AM - lrpSpeak Error - InitIO()->InitializeAB8SS()...failed. Shutting down plugin
    8/18/2008 1:46:43 AM - Info - Finished initializing plug-in lrpSpeak
    Marty
