Hi!
I have a Hometroller SEL Pro. I am still running Mono 3.2.8 because if I update to Mono 5, it breaks mono-devel (due to end of life of LST 14.04.01). This is an empty installation (just Zwave plugin).
If I install 3.0.2.0 and try to add a Hub I get the following error:
Posting back to plugin web page MeiHarmonyHub_Config: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
With the latest Beta, it simply says "There was no device found at the IP address." and the log record:
2018-06-19 10:45:08,013 DEBUG [5] HSPI - Posting back data on page (MeiHarmonyHub_Config) with data: IP_address=192.168.2.241&id=hub
_device_add&hub_device_add=Submit
2018-06-19 10:45:08,014 DEBUG [5] HSPI - new Hub with IP address (192.168.2.241) provided. Is it valid?
2018-06-19 10:45:08,320 DEBUG [5] HSPI - Was a new hub found at IP? False
2018-06-19 10:46:21,320 DEBUG [5] HSPI - Shutting down connections to hubs...
2018-06-19 10:46:21,402 INFO [1] HSPI - Connection to homeseer lost, exiting
2018-06-19 10:46:27,253 DEBUG [5] HSPI - It took 23ms to load the knownDevices file into memory.
2018-06-19 10:46:27,309 INFO [5] HSPI - Updating new settings with defaults. Previous version: 3.0.3.14; Current Version: 3.0.3.14
2018-06-19 10:46:27,312 DEBUG [5] HSPI - Settings changed. Saving settings
2018-06-19 10:46:27,358 DEBUG [5] HSPI - It took 41ms to save the settings (HSPI_MeiHarmonyHub.Classes.Settings) to file
2018-06-19 10:46:27,360 INFO [5] HSPI - Initializing Clients.
2018-06-19 10:46:27,364 INFO [5] HSPI - Registering Triggers.
2018-06-19 10:46:27,366 DEBUG [5] HSPI - Registering Triggers
2018-06-19 10:46:27,373 INFO [5] HSPI - Registering Actions.
2018-06-19 10:46:27,376 DEBUG [5] HSPI - Registering Actions
2018-06-19 10:46:27,381 DEBUG [5] HSPI - Polling Timers: adding timer: DeviceStatusUpdate at pollInterval: 86400000
2018-06-19 10:46:27,384 DEBUG [5] HSPI - Polling Timers: timer: DeviceStatusUpdate Started
2018-06-19 10:46:27,386 DEBUG [5] HSPI - Polling Timers: adding timer: SleepTimerUpdate at pollInterval: 0
2018-06-19 10:46:47,141 DEBUG [5] HSPI - Posting back data on page (MeiHarmonyHub_Config) with data: IP_address=192.168.2.241&id=hub
2018-06-19 10:46:47,153 DEBUG [5] HSPI - new Hub with IP address (192.168.2.241) provided. Is it valid?
2018-06-19 10:46:47,553 DEBUG [5] HSPI - Was a new hub found at IP? False
I have also tried the manual JSON trick to insert the HUB and it doesn't work.
Could you please let me know if Mono 5 is required? In a Docker Container I was able to install MeilHarmony without any problem, but it had Mono 5.
Jose
Jose
