Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. |
Help with this error.
I have 3.1.0.1 installed. Plugin is working just errors in the logs.
Looking at it now I also see it keeps saying "Activities to PowerOff" but I wasn't powering off. The first command was to power off then it repeats it.
Sep-11 10:38:19 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:38:15 AM Device Control Device: MeiHarmonyHub Living Room Living Room Activities to PowerOff (-1) by/from: CAPI Control Handler Sep-11 10:35:19 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:35:09 AM Device Control Device: MeiHarmonyHub Living Room Living Room Activities to PowerOff (20690033) by/from: CAPI Control Handler Sep-11 10:33:15 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:32:57 AM Device Control Device: MeiHarmonyHub Living Room Living Room Activities to PowerOff (20487719) by/from: CAPI Control Handler
I also have more then one harmony (5 actually) and same problem. First thing was "power on tv" then i tried netflix then power off. The TV is working, just the error in the logs.
Sep-11 10:44:32 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:44:29 AM Device Control Device: MeiHarmonyHub Master Bedroom Master Bedroom Activities to Power on TV (28024576) by/from: CAPI Control Handler Sep-11 10:43:46 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:43:42 AM Device Control Device: MeiHarmonyHub Master Bedroom Master Bedroom Activities to Power on TV (27369659) by/from: CAPI Control Handler Sep-11 10:43:05 AM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object. Sep-11 10:43:02 AM Device Control Device: MeiHarmonyHub Master Bedroom Master Bedroom Activities to Power on TV (27367539) by/from: CAPI Control Handler
Originally posted by integlikewhoa View PostI have 3.1.0.1 installed. Plugin is working just errors in the logs.
Originally posted by integlikewhoa View PostI have reverted and same issue is present.
Let me step back to maybe point you to my error (probley user error). I have been using the original harmony plugin for some time now. I just installed your version (trial) today and I have not uninstalled but disabled the old plugin.
Ok, so the issue is with setting the powerOff activity?
Let me add some code to that part of the code tonight and release an new version. I may know what is happening.
Originally posted by sirmeili View PostCan you send me your HSPI_MeiHarmonyHubs_KnownHubs.json file contents? What I'm specificlly looking for is if there is a node called "ActivityVoiceControlMappings" for each of the hubs and what it's value is.
Thanks looking forward to it.
https://forums.homeseer.com/forum/au...-now-available
