I have two Harmony hubs, each linked to a Harmony Touch remote. I've had these working for a little while now.
With the first hub, I am using the free plug-in (I don't need activity updates in HomeSeer, just the ability to set the activity and to control devices).
Tonight, I tried to add the 2nd hub to the free plug-in, but it won't connect/doesn't see it. So, I thought I would give your plug-in a try. It's not working with it either. I get this in the log.
I have the other plug-in disabled for this hub, but still controlling the other hub. I've tried changing this hub's IP address (Static from the router), but that doesn't change anything. I can ping it with no errors from the HomeSeer PC. It also works fine from the phone ap. I've also tried depowering the hub and repowering it. I've also tried it with the Windows firewall turned off.
Would anyone have any further troubleshooting steps for me to try to resolve this? Below are the HomeSeer details.
Dec-11 9:09:29 PM | MeiHarmonyHub: Error | The Connection to Hub with ID failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
Dec-11 9:09:29 PM | MeiHarmonyHub: Error | The Connection to Hub with ID failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.1.28:5222 |
System Information | |
Current Date/Time: | 12/11/2018 9:19:33 PM Central Standard Time |
HomeSeer Version: | HS3 Pro Edition 3.0.0.435 (Windows) |
HomeSeer: | Is Registered |
Operating System: | Microsoft Windows 10 Pro - Work Station |
OS Version: | 10.0.17134 Service Pack: 0.0 |
System Uptime: | 0 Days 1 Hour 39 Minutes 39 Seconds |
User Name and Access Level: | xxxxxxxxxxx(Admin) |
LAN IP Address: | 192.168.1.45 (server) |
Client IP Address: | 192.168.1.116 (Joe-PC) |
External IP Address: | 127.0.0.1 (server) Unable to get WAN IP, MyHS and Find service disabled in setup |
Network Adapter: | Adapter -> Intel(R) 82567V-2 Gigabit Network Connection IP: 192.168.1.45/24 MAC: 00:1D:72:BE![]() |
Network Adapter: | HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1 |
Web Server Port: | 81 |
Number of Devices: | 472 |
Number of Events: | 406 |
Event Last Ran: | Weather : Get Small Radar png, Ran at 12/11/2018 9:16:32 PM |
Number of unique event scripts used: | 1 |
Connected Speaker Clients: | SERVER (127.0.0.1)![]() |
Plug-Ins Enabled: | BLBackup:,BLUPS:,BLShutdown:,drhsIpPlugIn:,BLSpeech:,Pushove r 3P:,BLOnkyo:,NetCAM:,PHLocation:,Insteon:,Z-Wave:,Harmony Hub:,MeiHarmonyHub:,Harmony Hub:Bedroom |
Processor Type and Speed: | Intel64 Family 6 Model 23 Stepping 10 at 2.18 GHz |
Modules/Threads: | 169 Modules, 141 Threads |
Available Threads: | 400 |
System Processes/Load: | 152 Processes, 4% Load |
Free / Total Physical Memory: | 5.56 GBytes / 7.97 GBytes (70% free) |
Free / Total Virtual Memory: | 6.66 GBytes / 9.22 GBytes (72% free) |
HomeSeer Memory Used: | 125 Mbytes |
Plug-In Memory Used: | 14 EXE Plug-Ins using 386 Mbytes |
