Logitech Local API Access - How to get the current version of the plugin to work
This is a sticky topic.
  • #31
    I am on version .201 and have blocked access. Should I stay on .201 and wait until the next update or should I update now.
    • #32
      I personally saw stability issues on .201 when blocking access, but if your hubs are working fine you could stay there. The benefit to moving to .210 is that when a newer version is ready, it will likely auto update for you (well, due to recent events, you might not consider that a benefit).
      Frank
      • #33
        I tried the update. I do not see the screen that I should see. So I tried by connecting my remote that hub updated to 206 the others are on 201
        • #34
          You may need to grab the newest version of the my Harmony software and reinstall it.
          Sent from my Pixel 2 XL using Tapatalk
          Frank
          • #35
            Finally got it. It did not work on chrome for me. Also I used the link below. Once I found this link it worked.
            https://setup.myharmony.com/remotere...efaultRRT.html
            • #36
              Just an FYI if you don't have Microsoft Silverlight installed you wont see the install button you need once I installed Silverlight the install button showed up.
              • #37
                I tried everything and no luck. I can't get that install button to light up.
                I updated all software and no joy. Hopefully they push an update out soon.
                HSPro on a Supermicro Atom|Z-Net
                Elo touchscreen client, Android Phones and Tablets, Xbox One
                Global Cach/Ultra-GCIR | Etherrain | Jon00 | Sonos | Blue Iris | URC Whole Home Remotes | Philips Hue | Nest | Grandstream | Leviton | Aeon Labs | Cooper | Kwikset | Evolve | Envisalink/DSC | Amazon Alexa/IFTT
                • #38
                  Make sure you are running the application full screen. That work for me as the install button was hidden off to the right
                  Sent from my SM-T813 using Tapatalk
                  • #39
                    I can see the button. It's just grayed out and lights up to be pressed.
                    • #40
                      Usually when it is greyed out it is because the USB connection between the PC and the hub is not made.
                      Randy Prade
                      Aurora, CO
                      Prades.net
                      • #41
                        Frank, thanxs for the procedure and steering, I've successfully update my two hubs to firmware .201. After scanning earlier posts I saw something (JON) that this version is only good to end of Dec?? if so then I guess this is the shortest firmware update as today is the 31st..... Mike
                        Computer: CUK Intel NUC7i7BNH
                        Op System: Windows 10 Pro - Work Station
                        HS Version: HS3 Pro Edition 3.0.0.435
                        Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
                        • #42
                          There is a beta of .210 hat Logitech released. There is a post describing how to do it. I'm on my way home and when I get there I'll post the link to it.
                          Edit: wait, this is that post. Version .201 will work but you cant sync as it will force a firmware update. If possible update to .210.
                          Frank
                          • #43
                            Hi, great plug-in (I think)
                            I have upgraded my HUB to .210 ( in IE with this link https://setup.myharmony.com/remotere...efaultRRT.html )
                            But stil the message "There was no device found at the IP address."
                            Anny idea I have the latest plugin version (3.1.0.6)
                            Regards Paul.
                            • #44
                              See error message in screenshot
                              • #45
                                Are you running this in Linux? I've seen this sometimes with Linux.
                                Frank
