unable to connect to hub
  • unable to connect to hub
    I have two hubs - when I try to add by IP is says their is no device for that IP. Idownloaded the beta and did a search if found both hubs. Now when I go to devices I can't select a hub even though they are both enabled. What do I do.
    What are you running HS3 on?
    MeiAutomtion Home
      I am having same problem. Running HS3 on Win10 VM
      They are on separate subnets
      Nevermind, Windows firewall was in the way.
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug Was a new hub found at IP? False
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug Is hub connected?: False
      Jan-27 7:51:46 AM MeiHarmonyHub: Error The Connection to Hub with ID failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
      Jan-27 7:51:46 AM MeiHarmonyHub: Error The Connection to Hub with ID failed with message: An attempt was made to access a socket in a way forbidden by its access permissions 192.168.2.137:5222
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug Debug Message for Hub : Attempting to connect to IP: 192.168.2.137 on port 5222
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug CheckAndStoreHub: Starting to connect to IPAddress: 192.168.2.137
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug new Hub with IP address (192.168.2.137) provided. Is it valid? True
      Jan-27 7:51:46 AM MeiHarmonyHub: Debug Posting back data on page (MeiHarmonyHub_Config) with data: IP_address=192.168.2.137&id=hub_device_add&hub_device_add=Su bmit
        So you are good then? (just want to make sure)
        MeiAutomtion Home
          I am having the same issue, added the Plugin, could not find my 2 hubs with the IP address, updated w the Beta. Scanned, found the 2 Hubs. Enabled everything. Cannot find the devices (no Hubs listed in the drop downs). Filling up my logs thought. All on the same network, no subsets.
          Feb-10 2:36:57 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:57 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with message: No connection could be made because the target machine actively refused it 192.168.1.203:5222
          Feb-10 2:36:55 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:55 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with message: No connection could be made because the target machine actively refused it 192.168.1.249:5222
          Feb-10 2:36:51 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:51 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with message: No connection could be made because the target machine actively refused it 192.168.1.203:5222
          Feb-10 2:36:49 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:49 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with message: No connection could be made because the target machine actively refused it 192.168.1.249:5222
          Feb-10 2:36:45 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:45 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with message: No connection could be made because the target machine actively refused it 192.168.1.203:5222
          Feb-10 2:36:43 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:43 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with message: No connection could be made because the target machine actively refused it 192.168.1.249:5222
          Feb-10 2:36:39 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:39 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with message: No connection could be made because the target machine actively refused it 192.168.1.203:5222
          Feb-10 2:36:37 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:37 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with message: No connection could be made because the target machine actively refused it 192.168.1.249:5222
          Feb-10 2:36:33 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:33 PM MeiHarmonyHub: Error The Connection to Hub with ID a180dfa6-3e0e-4862-8a5b-60d4dd2310cc failed with message: No connection could be made because the target machine actively refused it 192.168.1.203:5222
          Feb-10 2:36:31 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
          Feb-10 2:36:31 PM MeiHarmonyHub: Error The Connection to Hub with ID ab9c247d-3f9d-45a6-9631-33b64c182f24 failed with message: No connection could be made because the target machine actively refused it 192.168.1.249:5222
            What version is your hub on? Do you have the beta firmware installed that has XMPP re-enabled?
            If not, instructions are here: https://forums.homeseer.com/forum/au...plugin-to-work
            MeiAutomtion Home
              sirmeili
              I have the same problem, started yesterday. It was working fine on .7 until yesterday... using Logitech's beta firmware
              I updated to .12 today same problem...
              Feb-20 8:50:25 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:25 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
              Feb-20 8:50:23 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:23 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
              Feb-20 8:50:21 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:21 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
              Feb-20 8:50:19 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:19 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
              Feb-20 8:50:17 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:17 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
              Feb-20 8:50:15 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with message: No connection could be made because the target machine actively refused it 192.168.2.52:5222
              Feb-20 8:50:15 PM MeiHarmonyHub: Error The Connection to Hub with ID 0066f031-f724-45f8-a5d6-88b465658b8f failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                Originally posted by Ltek View Post
                sirmeili
                Yeah, they updated the firmward, you now have to opt into XMPP. Instructions are here:
                https://forums.homeseer.com/forum/au...il-you-do-this
                MeiAutomtion Home
                  I ended up having to reset my entire hub... looks like the firmware update (which I didnt update) must have screwed up something big time. My harmony remote worked fine but the app would not connect. to it.
