I finally had time to try the new firmware. I installed plug-in 3.1.0.13. I had all Internet access blocked for the hubs, so I had to remove that firewall rule. Then I updated and synchronized the first hub using my PC. I enabled XMPP through the iOS app. The hub would not connect. Restarted the plug-in and it reconnected. The exact same process played out on hubs #2 and #3. Everything is working as it was. I did get a rash of errors each time I connected a hub, but they have not recurred.
Feb-23 7:54:26 PM Fatal Object reference not set to an instance of an object.
Feb-23 7:29:13 PM Fatal Object reference not set to an instance of an object.
Feb-23 6:57:04 PM Fatal Object reference not set to an instance of an object.
Feb-23 6:57:03 PM Fatal Object reference not set to an instance of an object.
Feb-23 6:57:02 PM Fatal Object reference not set to an instance of an object.
