MeiHarmonyHub version 3.1.0.12 (Beta) is now available!
  • MeiHarmonyHub version 3.1.0.12 (Beta) is now available!
    MeiHarmonyHub v3.1.0.12 is now available in the HomeSeer store and in the updater (Beta Section)!
    The following are included:
    • Fix for a bug introduced in 3.1.0.11 that when it adjusts the Hub ID in your settings, it no longer matches the devices addresses. The hub will check each device on each plugin start up and ensure each devices Address matches the unique ID in the settings for that hub.
    IF YOU HAVE A COMPLEX SETUP (FOR THIS PLUGIN), PLEASE BACK UP YOUR SETTINGS BEFORE RUNNING THIS FOR THE FIRST TIME. THIS IS JUST A PRECAUTION. AFTER THE PLUGIN STARTS UP THE FIRST TIME, CHECK TO MAKE SURE ANY VIRTUAL REMOTES, VOICE COMMAND DEVICES, ETC. STILL WORK.
    Please see the full descriptions here:
    https://forums.homeseer.com/showthread.php?t=194095
    Release notes Here:
    https://forums.homeseer.com/showthread.php?t=194096
    Request new Features Here:
    https://forums.homeseer.com/showthread.php?t=194097
    MeiAutomtion Home
    So far so good. Used the fix button for each hub.
      Although, I did catch this in the log.
      Feb-18 6:54:09 PM Error Caught Error during DeviceValueChanged: The given key was not present in the dictionary.
      Feb-18 6:54:06 PM Error Caught Error during DeviceValueChanged: The given key was not present in the dictionary.
        Hmm....can you turn on debug logging in the general settings and reproduce then send me the log file?
        MeiAutomtion Home
          Thus far, that error has not repeated.
          My bedroom hub did "lock up" a little while ago and that caused several errors in the log. I recovered it by a hard reboot (hold power and menu till the remote screen goes off). This is the same hub that does this every now and then. The remote is unresponsive when it happens. I still plan to replace it with a spare that I have to see if it is some hardware fault with the hub.
          If I can figure out how to reproduce the "key" error above, I will turn on debug and capture it for you.
            Hi, I have upgraded to this version but am having a problem. Instead of the switch to enable the plugin I see 'loaded remotely' with plug in status disabled and in the log I see:
            Feb-20 20:45:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:45:14 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:45:10 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:45:01 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:44:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:44:01 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:43:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:43:01 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:42:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:42:01 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:41:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:41:01 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:40:31 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:40:17 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:40:15 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:40:00 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:39:30 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:39:00 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:38:30 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:38:00 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:37:36 Device Control Device: MeiHarmonyHub MeiHarmonyHub Front Room Hub Hub to Connnect (1) by/from: CAPI Control Handler
            Feb-20 20:37:30 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:37:16 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:37:14 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:37:00 Warning Cannot access remote plugin MeiHarmonyHub
            Feb-20 20:36:53 Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
            Feb-20 20:36:50 Updater Install/Update of package MeiHarmonyHub was successful.
            Can you help please?
              What are your system details?
              MeiAutomtion Home
                Hi Frank,
                my hubs have updated to 4.15.250 before I saw the message here.
                I’m running x.12 of the plugin
                Let me know if it is different system details you’re after
                Simon
                  Hi Frank,
                  Simon
                  Tools -> About HomeSeer ->Details for Support (button at bottom of the table) -> copy/paste the section "Message Board"
                  MeiAutomtion Home
                    Thanks!
                    Current Date/Time: 21/02/2019 04:39:11
                    HomeSeer Version: HS3 Pro Edition 3.0.0.478
                    System Uptime: 31 Days 20 Hours 57 Minutes 19 Seconds
                    IP Address: 192.168.0.55
                    Number of Devices: 155
                    Number of Events: 12
                    Available Threads: 400
                    HSTouch Enabled: True
                    Event Threads: 0
                    Event Trigger Eval Queue: 0
                    Device Exec Queue: 0
                    HSTouch Event Queue: 0
                    Email Send Queue: 0
                    Enabled Plug-Ins
                    1.17.0.0: Big5
                    1.0.4.0: BLShutdown
                    3.0.0.51: EasyTrigger
                    3.0.2.3: izHeatmiserNEO
                    3.0.1.5: izTexecom
                    3.0.0.7: Neato
                    3.1.0.26: Sonos
                    3.0.3.5: YR Weather
                      GTI_SI are you trying to run this plugin Remote?
                      MeiAutomtion Home
                        Hi Frank, I am connecting over the web interface using a different machine but on the same LAN.
                          Sorry, I meant is the plugin running on the same machine as HS3? It says it's having trouble with the remote plugin.
                          MeiAutomtion Home
                            Ah!! Not that I’m aware of, I didn’t know that capability existed. How would I check?
                              If you are installing via the updater, they would not be remote... but it's odd. The plugin appears to not want to start. can you check if the log file is there: [hs3 isntall directory]/logs/MeiHarmonyHubYYYYMMDD.log (where YYYYMMDD is the currrent date)
                              MeiAutomtion Home
