I am trying out this plugin but it won't add any hubs. I do have XMPP enabled and have the latest trial from the homeseer store (not the beta's though). Plugin starts okay but when I type in an IP address I get the following error in the log...
It seems like an authentication error but I can't find anyplace to actually type in my username and password?
Both my hubs are currently working with the "Other" Harmony plugin so I know they should work...
Feb-20 18:09:21 | MeiHarmonyHub: Error | The Connection to Hub with ID failed with stack trace: at HarmonyHub.Client.GetSessionToken(String ip, String username, String password, Boolean bypassLogitech) at HarmonyHub.Client.Authenticate() at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
Feb-20 18:09:21 | MeiHarmonyHub: Error | The Connection to Hub with ID failed with message: AuthToken swap failed. |
