Errors started a couple of days ago
  • Errors started a couple of days ago
    I'm getting these errors every minute or 2 but they are too generic to chase. All 3 of my hubs seem to be working.
    Mar-12 12:09:00 PM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object.
    Mar-12 12:08:00 PM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object.
    Mar-12 12:07:00 PM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object.
    Mar-12 12:05:00 PM Error Calling HSEvent in plugin MeiHarmonyHub, Instance :Object reference not set to an instance of an object.
    Randy Prade
    Aurora, CO
    Prades.net
    Are you on 3.1.0.14? I think I might know what is causing it.
    MeiAutomtion Home
      Yes, it looks like I updated on 3/10. That also may be when the errors began. I forgot I had applied the update.
      Randy Prade
      Aurora, CO
      Prades.net
        Ok. I'm pretty sure it is related to how I'm trying to cache a list of HomeSeer devices. I will check it out tonight. I will also check my local install as I'm running .14 as well.
        MeiAutomtion Home
          Filtering my log, it is clear the errors began at the time I updated to .14 on the afternoon of March 10. I don’t usually look at my log unless there are problems. I happened to look at it last night and discovered the errors. The plug-in has not crashed and does seem to be working.
          Randy Prade
          Aurora, CO
          Prades.net
            rprade this is fixed in 3.1.0.15 in the beta section of the updater.
            MeiAutomtion Home
