MeiHarmonyHub version 3.1.0.16 (Beta) is now available!
  • MeiHarmonyHub version 3.1.0.16 (Beta) is now available!
    MeiHarmonyHub v3.1.0.16 is now available in the HomeSeer store and in the updater (Beta Section)!
    The following are included:
    • Fixed issue with config screens not showing.
    Please see the full descriptions here:
    https://forums.homeseer.com/showthread.php?t=194095
    Release notes Here:
    https://forums.homeseer.com/showthread.php?t=194096
    Request new Features Here:
    https://forums.homeseer.com/showthread.php?t=194097
    MeiAutomtion Home
    I have updated the plugin but still not seeing the device config screen.
      Do you see any of the other config screens?
      Can you tell me the details of your system?
      MeiAutomtion Home
        I updated to this version several days back, and all seemed okay as far as events went. I didn't try any of the plugin menus, such as device config.
        Today, I added three new devices and a couple of new activities to one of my two hubs.
        When I did this, it resulted in:
        Mar-23 10:52:26 AM Error The Connection to Hub with ID 8b839c60dc27ae9adad8d66be1cd1087eaeabd0b failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml)
        Mar-23 10:52:26 AM Error The Connection to Hub with ID 8b839c60dc27ae9adad8d66be1cd1087eaeabd0b failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
        I didn't notice at the time. Later I noticed that the hub was not connected on the device screen. It said forced disconnect or something like that. I hit "connect." Result:
        Mar-23 4:16:11 PM Error The Connection to Hub with ID 8b839c60dc27ae9adad8d66be1cd1087eaeabd0b failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) at HarmonyHub.Client.OpenStream(Int32 heartbeatInterval) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
        Mar-23 4:16:11 PM Error The Connection to Hub with ID 8b839c60dc27ae9adad8d66be1cd1087eaeabd0b failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
        However, I can now control activities, except of course the new ones and new devices.
        When I go to the device config screen, nothing happens for either of my two hubs that I select.
        Solutions?
        Current Date/Time: 3/23/2019 4:29:06 PM
        System Uptime: 15 Days 22 Hours 22 Minutes 12 Seconds
        IP Address: 192.168.1.45
        Number of Devices: 545
        Number of Events: 419
        Available Threads: 400
        HSTouch Enabled: True
        Event Threads: 69
        Event Trigger Eval Queue: 0
        Device Exec Queue: 0
        HSTouch Event Queue: 0
        Email Send Queue: 0
        In Virtual Machine: No MFG: gateway
        Enabled Plug-Ins
        2.0.59.0: BLBackup
        2.0.66.0: BLOnkyo
        1.0.4.0: BLShutdown
        2.0.76.0: BLSpeech
        2.0.24.0: BLUPS
        0.0.0.31: drhsIpPlugIn
        3.0.7.5: Insteon
        3.1.0.16: MeiHarmonyHub
        3.0.0.14: NetCAM
        3.0.1.125: PHLocation
        0.0.0.45: Pushover 3P
        3.0.1.258: Z-Wave
          I am running homeseer on a windows 10 laptop.
          Operating System: Microsoft Windows 10 Home - Work Station
          System Uptime: 0 Days 3 Hours 55 Minutes 33 Seconds
          Number of Devices: 865
          Number of Events: 306
          Available Threads: 800
          Event Threads: 1
          Email Send Queue: 0
          In Virtual Machine: No MFG: lenovo
          Enabled Plug-Ins
          1.0.0.147: Arduino Plugin
          2.0.59.0: BLBackup
          3.1.3.33206: Blue-Iris
          0.0.0.3: Device Comparison 3P
          0.0.0.23: DoorBird
          1.0.0.0: Invertor
          1.0.0.0: ModbusMeter
          1.1.0.0: Monoprice Amp
          1.0.0.0: NessAlarm
          0.0.0.46: Pushover 3P
          3.0.6.8: SDJ-Health
          1.0.0.0: Sensibo
          1.0.0.0: WeatherDisplay
          3.0.1.252: Z-Wave
          Everything works, but when I go to device Config tab and select a hub, I do not see anything under then selected device (see attachment). I used to see another dropdown with all devices listed.
Name:	Harmony Config.PNG
            Are there any files that we could edit to fix this?
              Sorry all,
              I fixed this last night. I will release a version today to fix it.
              Sorry it took so long.
              MeiAutomtion Home
                No problem.
                  All that last issue is fixed in 3.1.0.17. Sorry it was a crazy weekend (trying to get as much done before the Florida heat kicks in). The release notes are here:
                  https://forums.homeseer.com/forum/au...-now-available
                  I will release it to the production stream in a few days. Right now it's in the beta section.
                  MeiAutomtion Home
