Plugin Start Is Pending
  • Plugin Start Is Pending
    After installing from the updater I try to enable the plugin and the status always says Plugin start is pending. I have removed and reinstalled but still get the same thing.
    The log has no errors, just the entries below but the plugin is not usable.
    Mar-28 7:56:30 PM Plug-In Finished initializing plug-in MeiHarmonyHub
    Mar-28 7:56:30 PM Plug-In Interface MeiHarmonyHub is running as a trial, 30 days remaining.
      Does the plugin show up in the plugins menu so you can get to the configs?
      MeiAutomtion Home
        No it does not show up in the menu or have a clickable link for the plugin name. I was a licensed user for the other Harmony plugin but have deleted the devices and plugin. I have attached a screen shot of my plugins page with pull down menu in case something seems off.
          There were no new devices created for your plugin.
          I saw your post about the other plugin that is no longer supported a few months ago but was not ready to dive in at that time. I'm ready now so I hope you can help me get it working.
            Can you copy/paste your system details located here: Tools > About HomeSeer > Click Display Details for Support > Then copy/paste the Message Board section.
            MeiAutomtion Home
              Current Date/Time: 4/1/2019 7:45:08 PM
              HomeSeer Version: HS3 Standard Edition 3.0.0.435
              Operating System: Microsoft Windows 8.1 with Bing - Work Station
              System Uptime: 49 Days 23 Hours 40 Minutes 23 Seconds
              IP Address: 192.168.1.10
              Number of Devices: 192
              Number of Events: 251
              Available Threads: 400
              HSTouch Enabled: True
              Event Threads: 0
              Event Trigger Eval Queue: 0
              Device Exec Queue: 0
              HSTouch Event Queue: 0
              Email Send Queue: 0
              Enabled Plug-Ins
              2.0.59.0: BLBackup
              3.0.0.32: ImperiHome
              3.1.0.16: MeiHarmonyHub
              3.0.0.93: weatherXML
              3.0.0.36: X10
              3.0.1.252: Z-Wave
                I left your plugin running for days and it still says a start is pending... I posted my system details above as requested.
                  Does the plugin version number matter? I see yours starts with 3.1 and the others are either 2.0 or 3.0...
                    No it doesn't. Can you PM me your settings file. it should be located in [hs3 install directory]/config/meiharmonyhub/HSPI_MeiHarmonyHub_settings.json
                    You can also check if there is a log. it will be in [hs3 install directory]/Logs and it will be either MeiHarmonyHubYYYYMMDD.log or MBPluginsYYYYMMDD.log (Where YYYYMMDD is the date the file was created, there should be 1 per day).
                    MeiAutomtion Home
                      It seems that I had the wrong .NET installed on the computer and just saw the error message. The plugin has loaded. Thank you for the help.
