My HS logs are being spammed with these messages for 2 out of my 3 hubs:
This just started today.
May-10 3:40:58 PM | Info | The Connection to Hub with ID e82088e71bbe3a3e8b9c32b9d2298ad6efc3c687 was closed |
May-10 3:40:58 PM | Error | The Connection to Hub with ID e82088e71bbe3a3e8b9c32b9d2298ad6efc3c687 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-10 3:40:58 PM | Error | The Connection to Hub with ID e82088e71bbe3a3e8b9c32b9d2298ad6efc3c687 failed with message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.0.100:5222 |
