Sorry if this has already been addressed somewhere, I've been racking my brain tryin to find a fix and didn't see it anywhere in the forum.
On the Harmony App (Android) you can take the buttons at the bottom of the Elite remote and assign them to control a device. Sadly this is limited to the list of approved devices, vendors and home automation companies approved by Logitech. This is circumvented "hopefully" through this excellent plug in from sirmeili.
So the app from Logitech allows you to use the physical buttons on the remote, to execute device commands. There are 2 lighting buttons, a rocker and two home automation buttons. You can use each of the 4 buttons for SHORT and LONG Press to execute commands. You technically have 9-10 possible commands on a physical button. This works great for HUE lighting, as Logitech has integrated HUE control as an approved smart lighting integration. The rocker lets you dim and brighten said light. Anything not on their list you cannot connect to. You can however go in and configure the buttons to be pressed and execute a device command, such as SAMSUNG TV > C or D. Whatever your device is, you can map the harmony to that command button.
Over in Homeseer, I created an event to control a device when the value on my Samsung TV changes to "C" turn on a light or "D" turn off a light. When I choose a command on Samsung TV in the dropdown menu and select either of the aforementioned C or D. works great! However on the remote, when pressing the physical button I mapped from the Harmony app, or even under Devices from the remote touchscreen > SamsungTV > D or C. Those commands fail to execute. By my tracing of steps, this should work...but it does not. I've been scratching my head on this one. Defeats the purpose if I can only execute specific triggers or events from the HomeSeer web page. Not sure why it only works there but the value doesn't change on the TV to complete the command from hard button presses.
Any thoughts??
Any thoughts??
