MeiHarmony connecting to 2 of 4 hubs
    I have 4 Harmony hubs. Meiharmony sees all 4 in the Hub Management panel. But when I enable 2 of the 4 I get errors below. The other 2 hubs work fine. I have removed and added back the problem hubs with no success. All 4 hubs are seen within the Harmony app. They work normally. Not sure what to try.
    I am using the 3.1.0.17 of Meiharmony. Log file attached as well.
    ay-21 11:16:18 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:16:18 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:16:12 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:16:12 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:16:06 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:16:06 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:16:00 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:16:00 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:54 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:54 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:48 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:48 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:42 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:42 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:36 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:36 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:30 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:30 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:24 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:24 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:18 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:18 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:15:12 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:15:12 PM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
    May-21 11:10:05 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:10:05 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
    May-21 11:09:59 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:09:59 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
    May-21 11:09:53 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:09:53 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
    May-21 11:09:47 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    May-21 11:09:47 PM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
    May-21 11:09:46 PM Plug-In Finished initializing plug-in MeiHarmonyHub
    May-21 11:09:46 PM Starting Plug-In MeiHarmonyHub loaded in 5706 milliseconds
    May-21 11:09:46 PM Starting Plug-In Plugin MeiHarmonyHub started successfully in 5303 milliseconds
    May-21 11:09:40 PM Starting Plug-In Initializing plugin MeiHarmonyHub ...
    May-21 11:09:40 PM Info Connection to homeseer successful.
    May-21 11:09:40 PM Info Plugin MeiHarmonyHub has connected. IP:127.0.0.1:60466
    May-21 11:08:15 PM Info Plugin MeiHarmonyHub with instance: has disconnected
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    Do they show as away in the harmony phone app?
    MeiAutomtion Home
      No Frank they are all available in the phone app.
        Do you have them with static IPs or using DHCP reservation in your router to keep the IP the same?
        MeiAutomtion Home
          DHCP. I tried fixing the ip in the mei setup and there was no change. I can reserve the ip in my router if you think that will help.
            I reserved the ip address in the non working hub. And now I am getting errors on the hub that was working. So nothing is working now Frank??
              can you PM me your configs and the IPs you believe are associated with each hub?
              MeiAutomtion Home
                Bob, I will look into this. I got your logs. Unfortunately work this week is crazy (I'm going on vacay next week) so I've been working crazy hours to get my team ready for my absence. I will check it out as soon as I can.
                MeiAutomtion Home
                  I’m going to delete everything and reinstall. It was all fine till I tried using the other hub. Had 2 of 4 working. Then everything went to hell. Any suggestions?
                    take a backup of the HS3 directory first. That way if you want to restore you can.
                    I'm not sure what's going on. Nromally those messages are network related (bad wifi, firewall, wring IP etc). I would check your settings (Files) vs the IPs you expect and make sure they are correct.
                    MeiAutomtion Home
                      I deleted the plug in. And deleted the Meiharmony config files that I could see. Reinstalled it. See log below. 1 out of 4 hubs connects now.
                      May-23 10:34:28 AM Z-Wave Device: Z-Wave System Watts Set to 9.824 (9.824 Watts)
                      May-23 10:34:25 AM Error The Connection to Hub with ID cae6dcfac24930b9779207ea274bfb87806f48f0 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:34:25 AM Error The Connection to Hub with ID cae6dcfac24930b9779207ea274bfb87806f48f0 failed with message: No connection could be made because the target machine actively refused it 192.168.1.80:5222
                      May-23 10:34:19 AM Error The Connection to Hub with ID cae6dcfac24930b9779207ea274bfb87806f48f0 failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:34:19 AM Error The Connection to Hub with ID cae6dcfac24930b9779207ea274bfb87806f48f0 failed with message: No connection could be made because the target machine actively refused it 192.168.1.80:5222
                      May-23 10:33:58 AM Z-Wave Device: Z-Wave System Watts Set to 9.864 (9.864 Watts)
                      May-23 10:33:53 AM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:33:53 AM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
                      May-23 10:33:46 AM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:33:46 AM Error The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222
                      May-23 10:33:28 AM Z-Wave Device: Z-Wave System Watts Set to 9.784 (9.784 Watts)
                      May-23 10:33:12 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:33:12 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
                      May-23 10:33:06 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:33:06 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222
                      May-23 10:33:00 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
                      May-23 10:33:00 AM Error The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 1
                        and in the app they show up as local and not "away" I've seen this recently where the hubs refuse to connect locally, even to the phone app (Note they will show up in the app, but be listed as "Away").
                        Have you tried an extended power cycle of the hubs (like 5-10min)?
                        MeiAutomtion Home
                          Havnt tried power cycle. Can do that. Not sure what you mean in the app local or away? I can connect to all my hubs both locally and remotely with the iphone app. Havnt tried the pc Harmony app. Which are you referring to?
                            Power cycle hub with 15 minute off time did not improve. Same errors
                              I mean in the mobile app. It will say "Away" if you're not on Wifi or if the hub is not on your same network. I've had his happen with my hubs recently where they only show away even though I know they ar on the same network as my phone.
                              In my example below, I turned off wifi just o you could see what I mean by "Away"
                              MeiAutomtion Home
