I have 4 Harmony hubs. Meiharmony sees all 4 in the Hub Management panel. But when I enable 2 of the 4 I get errors below. The other 2 hubs work fine. I have removed and added back the problem hubs with no success. All 4 hubs are seen within the Harmony app. They work normally. Not sure what to try.
I am using the 3.1.0.17 of Meiharmony. Log file attached as well.
ay-21 11:16:18 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:16:18 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:16:12 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:16:12 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:16:06 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:16:06 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:16:00 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:16:00 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:54 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:54 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:48 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:48 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:42 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:42 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:36 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:36 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:30 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:30 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:24 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:24 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:18 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:18 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:15:12 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:15:12 PM | Error | The Connection to Hub with ID 1a25414d9a67277e783d2bd24376562b19a98cdd failed with message: No connection could be made because the target machine actively refused it 192.168.1.69:5222 |
May-21 11:10:05 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:10:05 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222 |
May-21 11:09:59 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:09:59 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222 |
May-21 11:09:53 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:09:53 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222 |
May-21 11:09:47 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
May-21 11:09:47 PM | Error | The Connection to Hub with ID c77f9064a7f80b7794e9f2b64d357b60f73b4c6c failed with message: No connection could be made because the target machine actively refused it 192.168.1.58:5222 |
May-21 11:09:46 PM | Plug-In | Finished initializing plug-in MeiHarmonyHub |
May-21 11:09:46 PM | Starting Plug-In | MeiHarmonyHub loaded in 5706 milliseconds |
May-21 11:09:46 PM | Starting Plug-In | Plugin MeiHarmonyHub started successfully in 5303 milliseconds |
May-21 11:09:40 PM | Starting Plug-In | Initializing plugin MeiHarmonyHub ... |
May-21 11:09:40 PM | Info | Connection to homeseer successful. |
May-21 11:09:40 PM | Info | Plugin MeiHarmonyHub has connected. IP:127.0.0.1:60466 |
May-21 11:08:15 PM | Info | Plugin MeiHarmonyHub with instance: has disconnected |
