Nope mine are all available and list Connect. But what is interesting hubs in my other home are also listed and can connect to them as well. I am able to access and control all my hubs in and out of my home. I’ve never seen the Away status you have.
MeiHarmony connecting to 2 of 4 hubs
Originally posted by bobsilver1 View PostEven with WiFi off I still see the Connect command.
Here's how it seems to work from the iPhone app.
Select your hub, then get the settings icon, select about, then versions.
The second row is the hub name. Off to the right it will have a cloud icon if it is "away" (connecting remotely via the cloud). It will have nothing there if it is "home" (connecting on the local lan.)
Do you have an android device you can test with to see if they show as Away or not? I've noticed this issue since .250 where hub refuse local connections from both the plugin and even Logitech's own apps. One of my hubs refused local connections for about 3 weeks earlier this year until it just started working all of a sudden.
I'll check your logs though in case I see something else. Work has been crazy and I had my son's preschool graduation last night. I'm taking PTO for the next week so should have time to investigate
Originally posted by bobsilver1 View PostFrank
XMPP was off! Didn’t know it had to be on. And I turned it off on my working hub before it stopped working!!! So operator error. All seems fine now. Thanks for the help. Btw don’t recall reading xmpp needed to be on. Thought it was a debug option. Thanks again. Bob
Originally posted by bobsilver1 View PostFrank. One more issue. Changed hub activity and meiharmony isn’t updating the activity changes. How do I force it to refresh?
Here is the debug log after adding an activity on Kitchen Hub
https://www.dropbox.com/s/2i1pzp15za...90524.log?dl=0
Originally posted by bobsilver1 View PostHere is the debug log after adding an activity on Kitchen Hub
