Can't display Device Config pages
  • #16
    Yeah, I still have this problem too. The device config page works for one of my two hubs, but not for the other.
    • #17
      During my trying to fix this problem I ended up deleting the hub from the plugin and re-adding it. I also deleted all the associated HS devices. After re-adding the hub the harmony devices page is working again. I did have to update all the events that use the harmony plugin.
      iCore5 Win 10 Pro x64 SSD
      HS3 Pro Edition 3.0.0.435 Windows
      BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
      • #18
        I have only one hub, I don't recall ever having that config menu display anything other then a blank screen. What's it supposed to have? Can anyone post a screen shot who has the config page working so I can see what I'm missing. Had this plugin over a year and never got that page to work. 3.1.0.18
        • #19
          I'm on 3.1.0.18 and still have this error.
          • #20
            Ok. I will try and reproduce locally.
            MeiAutomtion Home
            • #21
              I have the same issue with nothing showing in the "Device Configuration" page. No errors show up in the logs even when I set "Debug" in the "HomeSeer Logging Level" option.
              • #22
                I still have the issue too. I have two hubs. If I select the first one, then the device config page works correctly. If I select the second hub, then nothing happens, other than the below error in the log.
                May-28 8:19:09 AM Error Posting back to plugin web page MeiHarmonyHub_Device_Config: Object reference not set to an instance of an object.-> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
                • #23
                  I'm on a deployment the next two nights. I'll be looking into this then. I also need to check if the version is correct. Has everyone who installed this used the release version and not the beta?
                  MeiAutomtion Home
                  • #24
                    I am using the released version.
