Can't display Device Config pages
    #61
    joegr can you try .22 in the beta section? I think that will fix all your issues. Sorry for the long delay for this fix.
    MeiAutomtion Home
      #62
      You are definitely making progress. Here is a sample from the device config screen.
      Note that the "Lamp J" commands are relatively new (a month or three old).
      When I go to edit an event with commands for this device, it no longer crashes.
      However, it does not show the newer commands to select. It shows the same, correct, number of commands, but the old ones are repeated instead of the new "J" commands. I haven't tried yet to see if the repeated commands are really the new "J" ones. I suspect that they are, but it will take trial and error to figure out which is which.
      Thanks for your help/support.
