K.
HS Not Seeing Activities
Originally posted by kwatt View PostNo, sorry been busy too.
It doesn't appear to see any changes to activities nor send to Harmony when it should do.
K.
K.
Originally posted by kwatt View PostWas a cure ever found to this as mine is still not working?
K.
(please note I'll try and check back on this, but work is super crazy right now with me workig 60-80 hour weeks and it's about to get work as we go into our final stretch)
Finally figured out how to connect and pull the logs. Sent you a link in a PM.
Regards,
Dennis
Originally posted by dennismccreery View PostIs there any way to get to these logs via the Homeseer Web UI? Or do I need to connect to the Linux instance?
Regards,
Dennis
Regards,
Dennis
Regards,
Dennis
Originally posted by sirmeili View PostIt logs to [hs3InstallPath]/Logs/MeiHarmonyHub/MeiHarmonyHubYYYYMMDD.log where YYYYMMDD is the date. will be log for each date with a maximum of 10 log files. ...
no sub-directory.
It logs to [hs3InstallPath]/Logs/MeiHarmonyHub/MeiHarmonyHubYYYYMMDD.log where YYYYMMDD is the date. will be log for each date with a maximum of 10 log files. I'll only need the one with the date of the error or at most that one and the day before (in case it spans more than 1 day).
Ok, turned HSSentry back off and put the MeiHarmonyHub logging in Debug mode (does it log into the main Homeseer log or somewhere else?) I'll wait for the next incident to see what's in the logs.
Regards,
Dennis
Not sure if this is correct but hope it helps.
K.Attached Files
Originally posted by dennismccreery View PostI didn't have it in debug mode when it crashed, and I also didn't have HSSentry turned on. Should I put the whole system in debug logging mode or just the plugin?
Turned HSSentry on (it was off) and it seems to be working now. Here's a log from the latest crash (before I turned on HSSentry). This section appears to be where the crash occurred, the message "Plugin MeiHarmonyHub is not responding but it is still running, not restarting yet." occurs over and over again as far back as I can go:
Jun-26 14:38:19 Startup ************************************************************ ********************
Jun-26 14:38:19 Startup HomeSeer version 3.0.0.534 Edition: HS3 Standard (SEL) Starting Now
Jun-26 14:38:18 Startup Settings Loaded.
Jun-26 14:38:18 Warning HomeSeer was not shut down successfully the previous time it was started.
Jun-26 14:38:18 Startup Loading Settings
Jun-26 08:34:23 Warning Plugin MeiHarmonyHub is not responding but it is still running, not restarting yet.
Jun-26 08:33:52 Warning Plugin MeiHarmonyHub is not responding but it is still running, not restarting yet.
Jun-26 08:33:24 Warning Plugin MeiHarmonyHub is not responding but it is still running, not restarting yet.
Jun-26 08:32:52 Warning Plugin MeiHarmonyHub is not responding but it is still running, not restarting yet.
