I keep getting the following errors with one hub, wondering if its something hub related or with the plugin?
I also see occasionally some hubs say "Forcefully Disconnected" but that is random when it happens however still annoying.
Here are the errors I am seeing currently.
The Connection to Hub with ID HUB2 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB1 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB4 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB3 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml) |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB4 failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB3 failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB2 failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. |
Jun-27 10:53:52 AM | Error | The Connection to Hub with ID HUB1 failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. |
Jun-27 10:47:26 AM | Error | The Connection to Hub with ID HUB4 failed with stack trace: at HarmonyHub.StreamParser.NextElement(String[] expected) at HarmonyHub.Client.GetSessionToken(String ip, String username, String password, Boolean bypassLogitech) at HarmonyHub.Client.Authenticate() at HarmonyHub.Client.Connect(Int32 heartbeatInterval) |
Jun-27 10:47:26 AM | Error | The Connection to Hub with ID HUB4 failed with message: Unexpected XML element, expected: challenge, success, failure; received: message; full element: System.Xml.XmlElement |
