Error when enabling plug in
    Jul-22 12:52:36 Error The Connection to Hub with ID [snipped ID] failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    Jul-22 12:52:36 Error The Connection to Hub with ID [snipped ID] failed with message: No connection could be made because the target machine actively refused it [snipped IP and port]
    Is this related to XMPP? Echo and Google Assistant can control the Harmony Hub just fine.
    Please advise. Thank you.
    Do you have XMPP enabled? If not, you'll need it to be enabled. I don't know if Logitech uses XMPP for Google/Alexa, but I doubt it since they tried to kill it the end of last year.
    Normaly that is a network issue (firewall or general wireless issue). The hubs have really crappy wifi in them and I hear they work best on channels 1, 6 and 11. Also, I have heard that a wonky power supply can cause the wifi to be flakey.
    MeiAutomtion Home
      I will check tonight and reply back. The "machine actively refused..." message is indicating that a network connection was made but the Hub refused to connect?
        After I enabled XMPP, all was well. Thanks for the support!
          NP.... glad it worked
          MeiAutomtion Home
