Using HSTouch with the plug in to control AV devices.
With a normal AV remote you press the volume button till the desired level is reached then release to stop increase/decrease.
If I use the plugin device repeat function for say volume up.
On HStouch keypress how do you stop the repeats when the key is released, or do you just have to let the number of designated repeats occur
