HUBS Force Disconnect
    Hi,
    multiple times daily I see that my Harmony events aren't woking. When I check, they have been force disconnected and the following logs are created:
    Sep-22 19:39:36 Error The Connection to Hub with ID f0f6147802ac88482cc44c6dfeb422de7249c1bb failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml)
    Sep-22 19:39:36 Error The Connection to Hub with ID 36f6cdea8ef60d440151af160913aa536f3444dc failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml)
    Sep-22 19:39:36 Error The Connection to Hub with ID 79048a0d8d7643de2a72fcc1bf73e88d96c76457 failed with stack trace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HarmonyHub.Client.Send(String xml)
    Sep-22 19:39:36 Error The Connection to Hub with ID f0f6147802ac88482cc44c6dfeb422de7249c1bb failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
    Sep-22 19:39:36 Error The Connection to Hub with ID 36f6cdea8ef60d440151af160913aa536f3444dc failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
    Sep-22 19:39:36 Error The Connection to Hub with ID 79048a0d8d7643de2a72fcc1bf73e88d96c76457 failed with message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
    Can you help please with resolving this? Many Thanks
    This looks like the errors I had earlier today until I turned on XMPP in the harmony app. To Enable XMPP from Harmony App: First connect to the hub with the issue, if you have multiple hubs. Go to... Menu > Harmony Setup > Add/Edit Devices & Activities > Remote & Hub > Enable XMPP
    See here for details: https://www.domoticz.com/wiki/Harmony_Hub
    Hope this helps
      This can happen for a few reasons. Some are network issues. How close is your hub to your wireless access point?
      MeiAutomtion Home
