Plugin hang when turning off HS3
    #16
    sirmeili
      #17
      Yup yup yup. I am going to look into it. I have seen some issues and I'm doing lots of testing locally. This is my biggest and probably "messiest" plugin since it was my first. I need do to some refactoring on it as well. Updates might be slow, but trust me this is not forgotten.
      MeiAutomtion Home
        #18
        Just to be sure . We talk about meiharmony , not meiku
          #19
          Yes. Meiku was the first, but MeiHarmonyHub was the first really complex one. I've actually refactored MeiKu since I moved to using my library for plugins. MeiHarmonyHub was the first plugin on that library and like I said, is a bit messy. I just need to clean up the code to make it more maintainable.
          MeiAutomtion Home
            #20
            Ha ok understood
              #21
              Is this bug gonna be fixed in next release? Thanks
                #22
                I still have not been able to reproduce or see anything in the logs that suggest why it's hanging. What kind of hardware are you running it on?
                MeiAutomtion Home
                  #23
                  Sorry I didn't realie this was on Linux. Installing the newest version on my Pi. It could be something up with Mono. Can you tell me what version of Mono you're running?
                  MeiAutomtion Home
                    #24
                    I am using the last stable 6.8.xxx
                    But the issue was thwre before i posted it on this thread.
                    it does not happen each time , but when it’s happen I hve to wait 5 mins for my machine to restart, or I kill the harmony process before restarting the pc.
                    thanks
                      #25
                      Do you still have my log ?
                        #26
                        Yes, from 9/25
                        MeiAutomtion Home
                          #27
                          Originally posted by sirmeili View Post
                          I checked your logs from a couple of months ago. I didn't see anything out of the ordinary in your logs. It doesn't even seem to have a long timeout in the logs or something that took a long time.
                          Isn't the problem here? : https://forums.homeseer.com/forum/au...12#post1328912
                            #28
                            Those were the logs I checked. I didn't see anything that takes a long time at the end. Unless I'm missing it.
                            MeiAutomtion Home
