Plugin hang when turning off HS3
Those were the logs I checked. I didn't see anything that takes a long time at the end. Unless I'm missing it.
Guest repliedOriginally posted by sirmeili View PostI checked your logs from a couple of months ago. I didn't see anything out of the ordinary in your logs. It doesn't even seem to have a long timeout in the logs or something that took a long time.
Isn't the problem here? : https://forums.homeseer.com/forum/au...12#post1328912
Guest repliedDo you still have my log ?
Guest repliedI am using the last stable 6.8.xxx
But the issue was thwre before i posted it on this thread.
it does not happen each time , but when it’s happen I hve to wait 5 mins for my machine to restart, or I kill the harmony process before restarting the pc.
thanks
Sorry I didn't realie this was on Linux. Installing the newest version on my Pi. It could be something up with Mono. Can you tell me what version of Mono you're running?
- Likes 1
I still have not been able to reproduce or see anything in the logs that suggest why it's hanging. What kind of hardware are you running it on?
Guest repliedIs this bug gonna be fixed in next release? Thanks
Guest repliedHa ok understood
Yes. Meiku was the first, but MeiHarmonyHub was the first really complex one. I've actually refactored MeiKu since I moved to using my library for plugins. MeiHarmonyHub was the first plugin on that library and like I said, is a bit messy. I just need to clean up the code to make it more maintainable.
- Likes 1
Guest repliedJust to be sure . We talk about meiharmony , not meiku
Yup yup yup. I am going to look into it. I have seen some issues and I'm doing lots of testing locally. This is my biggest and probably "messiest" plugin since it was my first. I need do to some refactoring on it as well. Updates might be slow, but trust me this is not forgotten.
Guest repliedNo probs , Thanks. Glad to see you back.
But will wait for the released version, which might be more specific to this issue.
Sorry, right when I thought work was getting easy, they started up with the "Work nights or weekends until we're done". I've release 3.1.0.18 which has some interim altered connection logic. I still have your logs and will still go through them, but see if this works any better for you.
