My system melted down and I had to do use the "system restore". When I install MeiHarmonyHub it no longer works. I swear I had to runs some command line commands on the linux box when I first got this running a couple of years ago. It seems to find the Hubs but get an error trying to connect. Both the beta and non beta versions gave me the same error. Maybe it didn't get completely uninstalled but I don't know the directories to delete manually from the Linux box. so I have not tried that yet. I have tried disable, enable, uninstall, reinstall and reboot.
Here is the error from the log.
Feb-06 8:56:54 AM | Debug | Connection status: Disconnected |
Feb-06 8:56:54 AM | Info | The Connection to Hub with ID 5de74255757d1578f952d4b4dcd54319b18fc037 was closed |
Feb-06 8:56:54 AM | Debug | Connection Closed to Hub: 5de74255757d1578f952d4b4dcd54319b18fc037; with guid: 928b3f6a-387e-49cf-89ee-ecfc23cd070e; Where: ; Unexpectedly disconnected?: False |
Feb-06 8:56:54 AM | Error | The Connection to Hub with ID 5de74255757d1578f952d4b4dcd54319b18fc037 failed with stack trace: at System.Runtime.Serialization.Json.JsonSerializationReader.De serializeGenericCollection (System.Type collectionType, System.Type elementType) [0x00000] in :0 at System.Runtime.Serialization.Json.JsonSerializationReader.Re adObject (System.Type type) [0x00000] in :0 at System.Runtime.Serialization.Json.TypeMap.Deserialize (System.Runtime.Serialization.Json.JsonSerializationReader jsr) [0x00000] in :0 at System.Runtime.Serialization.Json.JsonSerializationReader.Re adObject (System.Type type) [0x00000] in :0 at System.Runtime.Serialization.Json.JsonSerializationReader.Re adRoot () [0x00000] in :0 at System.Runtime.Serialization.Json.DataContractJsonSerializer .ReadObject (System.Xml.XmlReader reader, Boolean verifyObjectName) [0x00000] in :0 |
Feb-06 8:56:54 AM | Error | The Connection to Hub with ID 5de74255757d1578f952d4b4dcd54319b18fc037 failed with message: Expected element 'item', but found 'Harmony' in namespace ''. Error at (1,254) |
Feb-06 8:56:54 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Hamrony Pair Message: {"serverIdentity":"5de74255757d1578f952d4b4dcd54319b18fc037" ,"hubId":"97","identity":"5de74255757d1578f952d4b4dcd54319b1 8fc037","status":"succeeded","protocolVersion":{"XMPP":"1.0" ,"HTTP":"1.0","RF":"1.0","WEBSOCKET":"1.0"},"hubProfiles":{" Harmony":"2.0"},"productId":"Pimento","friendlyName":"Living Hub"} |
Feb-06 8:56:54 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Auth string: |
Feb-06 8:56:54 AM | Debug | Message received from Hub: |
Feb-06 8:56:53 AM | Debug | Message Sent to Hub: method=pair:name=foo#iOS8.3.0#iPhone |
Feb-06 8:56:53 AM | Debug | Message received from Hub: |
Feb-06 8:56:53 AM | Debug | Message Sent to Hub: AGd1ZXN0QHguY29tAGd1ZXN0 |
Feb-06 8:56:53 AM | Debug | Message received from Hub: PLAIN |
Feb-06 8:56:53 AM | Debug | Message Sent to Hub: |
Feb-06 8:56:53 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Authenticating on IP: 192.168.118.13 on port 5222. |
Feb-06 8:56:53 AM | Starting Plug-In | Plugin MeiHarmonyHub started successfully in 6479 milliseconds |
Feb-06 8:56:53 AM | Info | Plugin started on version: 3.1.0.17 |
Feb-06 8:56:53 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Opening stream on IP: 192.168.118.13 on port 5222. |
Feb-06 8:56:53 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Attempting to get stream on IP: 192.168.118.13 on port 5222. |
Feb-06 8:56:53 AM | Debug | Polling Timers: adding timer: SleepTimerUpdate at pollInterval: 0 |
Feb-06 8:56:53 AM | Debug | Polling Timers: timer: DeviceStatusUpdate Started |
Feb-06 8:56:53 AM | Debug | Debug Message for Hub 5de74255757d1578f952d4b4dcd54319b18fc037: Attempting to connect to IP: 192.168.118.13 on port 5222 |
Feb-06 8:56:53 AM | Debug | Hub: 5de74255757d1578f952d4b4dcd54319b18fc037 Connection Attempt 1 |
Feb-06 8:56:53 AM | Debug | Polling Timers: adding timer: DeviceStatusUpdate at pollInterval: 86400000 |
Feb-06 8:56:53 AM | Info | Initializing hub: 88e5f48967cd0e6fc0214bee15f27ed6bac2a0b3 |
Feb-06 8:56:53 AM | Info | Initializing hub: 5de74255757d1578f952d4b4dcd54319b18fc037 |
Feb-06 8:56:53 AM | Info | Initializing hub: 59ad1363d5d575d8402290406ef99984ff1720b6 |
Feb-06 8:56:53 AM | Info | Number of hubs: 3 |
Feb-06 8:56:53 AM | Info | Initializing Clients. |
Feb-06 8:56:48 AM | Info | Found hub at IP 192.168.118.14 |
Feb-06 8:56:48 AM | Info | Found hub at IP 192.168.118.15 |
Feb-06 8:56:48 AM | Info | Found hub at IP 192.168.118.13 |
