MeiHarmonyHub version 3.1.0.18 (Beta) is now available!
    MeiHarmonyHub v3.1.0.18 is now available in the HomeSeer store and in the updater (Beta Section)!
    The following are included:
    • This is a stop gap fix. From now on pressing "Disconnect" should ensure the client object is completely removed, even if it thinks it's already disconnected.
    • This is a stop gap fix. From now on Pressing "Connect" should disconnect (ensuring the client object is completely removed) and then a connection is re-attempted. This will occur even if the hub is already connected.
    • The above are stop gap fixes while I continue on the rewrite of the communication logic.
    Please see the full descriptions here:
    https://forums.homeseer.com/showthread.php?t=194095
    Release notes Here:
    https://forums.homeseer.com/showthread.php?t=194096
    Request new Features Here:
    https://forums.homeseer.com/showthread.php?t=194097
    Thanks for the fix - even if temporary! Installed and will let you know of any issues. Appreciate it.
      This update didn't actually change the version number for me, i tried it twice, once without shutting the plugin down first and a second time with shutting the plugin down manually (updating and then starting the plugin again). After both attempts where installation was logged successful, the version number remains at 3.1.0.16 for me. Any thoughts on how I would go about and troubleshoot this? HS3 ZEE S2 Edition 3.0.0.531
      (log reads from bottom to top)
      May-23 1:51:56 AM Plug-In Finished initializing plug-in MeiHarmonyHub
      May-23 1:51:56 AM Starting Plug-In MeiHarmonyHub loaded in 8214 milliseconds
      May-23 1:51:56 AM Starting Plug-In Plugin MeiHarmonyHub started successfully in 6574 milliseconds
      May-23 1:51:49 AM Starting Plug-In Initializing plugin MeiHarmonyHub ...
      May-23 1:51:49 AM Info Connection to homeseer successful.
      May-23 1:51:49 AM Info Plugin MeiHarmonyHub has connected. IP:127.0.0.1:37406
      May-23 1:51:10 AM Updater Install/Update of package MeiHarmonyHub was successful.
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/html/images/MeiHarmonyHub/Status/remote-icon-rotated.png
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/html/images/MeiHarmonyHub/remote-icon-rotated.png
      May-23 1:51:10 AM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs _KnonwHubs.json
      May-23 1:51:10 AM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs _Settings.json
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/bin/MeiHarmonyHub/Newtonsoft.Json.dll
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/bin/MeiHarmonyHub/Serilog.Sinks.File.dll
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/bin/MeiHarmonyHub/Serilog.dll
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/bin/MeiHarmonyHub/MBPlugins.dll
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/bin/MeiHarmonyHub/CommandLine.dll
      May-23 1:51:10 AM Updater Copying file: /usr/local/HomeSeer/HSPI_MeiHarmonyHub.exe.config
      May-23 1:51:10 AM Updater Installing package MeiHarmonyHub
      May-23 1:51:10 AM Updater Update HSPI_MeiHarmonyHub.exe downloaded successfully
      May-23 1:51:09 AM Updater Downloading update: MeiHarmonyHub
      May-23 1:51:09 AM Updater Starting download of updates
      May-23 1:50:12 AM Info Plugin MeiHarmonyHub with instance: has disconnected
      May-23 1:50:09 AM Plug-In Shutting down Plug-In: MeiHarmonyHub
      After update and refreshing browser - this is what is shown on the plugins screen (note version number still stuck at 3.1.0.16)
        Same for me as well. Did update, (see log below) and still shows current version 3.1.0.16, and shows update 3.1.0.18 available.
        May-24 1:10:55 PM Updater Install/Update of package MeiHarmonyHub was successful.
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\MeiHarmonyHub\Status\remote-icon-rotated.png
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\MeiHarmonyHub\remote-icon-rotated.png
        May-24 1:10:55 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_KnonwHubs.json
        May-24 1:10:55 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_Settings.json
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Newtonsoft.Json.dll
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.Sinks.File.dll
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.dll
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\MBPlugins.dll
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\CommandLine.dll
        May-24 1:10:55 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_MeiHarmonyHub.exe.config
        May-24 1:10:54 PM Updater Installing package MeiHarmonyHub
        May-24 1:10:54 PM Updater Update HSPI_MeiHarmonyHub.exe downloaded successfully
        May-24 1:10:53 PM Updater Downloading update: MeiHarmonyHub
        May-24 1:10:53 PM Updater Starting download of updates
          Same here
            Same for me
              I will release a beta with the correct version then put it in for HST to approve for production. It's must've forgot to increase the version in the assembly.
                I just tried to update from 3.1.0.16 to 3.1.0.18 by disabling the plugin clicking on the update and installing, everything says that the install was successful but the version number doesn't update and it still shows that an update is available.
                May-26 8:06:54 AM Updater Install/Update of package MeiHarmonyHub was successful.
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\MeiHarmonyHub\Status\remote-icon-rotated.png
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\MeiHarmonyHub\remote-icon-rotated.png
                May-26 8:06:54 AM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_KnonwHubs.json
                May-26 8:06:54 AM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_Settings.json
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Newtonsoft.Json.dll
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.Sinks.File.dll
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.dll
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\MBPlugins.dll
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\MeiHarmonyHub\CommandLine.dll
                May-26 8:06:54 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_MeiHarmonyHub.exe.config
                May-26 8:06:54 AM Updater Installing package MeiHarmonyHub
                May-26 8:06:54 AM Updater Update HSPI_MeiHarmonyHub.exe downloaded successfully
                May-26 8:06:53 AM Updater Downloading update: MeiHarmonyHub
                May-26 8:06:53 AM Updater Starting download of updates
                Plugin's:
                  This is a known issue. I forgot to change the version number in the assembly when releasing the last version. You do actually have .18 installed, it's just reporting as .16
                  The beta is also .18 with the wrong internal version. I will have to update it to .19 to get it to go through.
                    If you were using the "production" version, it was for some reason still .16 even though I know I submitted .18 for approval. For now I have increased the version number on both the production and the beta to 3.1.0.19 and pushed it up. You can access the beta now, the production one tomorrow. They are the same exact version.
                      I know you deleted your comment, but I put it in the wrong spot by accident. It should be in the right place now (for anyone who might have also gone looking for it already and couldn't find it)
                        Thanks Frank. Do you hav time to check this please? https://forums.homeseer.com/forum/au...urning-off-hs3
                          Hi frannk , since this update I got this cpu usage non stop.. just realized it.
                          I went back to .16 for now
                          edit ...even when going back to 3.1.0.16 and restarting the plugin... the cpu is stil a 220% ( maybe related to the last issue i posted here at #12). I guess the last plugin process didn't shut down or something.
                          will kill the process.
                          edit 2: seems ok after killing and starting 3.1.0.16 again
                            can you check the logs to see if it's doing something over and over?
                              it happened today again with v 3.1.0.16. I sent you the log a couple months ago , are you ok with that?
