Help - I Broke It!
  • Help - I Broke It!
    Help, please. I can't seem to get the hub to connect and keep getting this error:
    Mar-20 00:14:51 Fatal A fatal error has occurred trying to connect to the hub:
    Mar-20 00:14:51 Error The Connection to Hub with ID 4d97790b8239ead10bfdadcd15511434c0744087 failed with stack trace: at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at HSPI_MeiHarmonyHub.Controllers.HarmonyHubController.GetHubCo nfig(String hubId) at HSPI_MeiHarmonyHub.Controllers.HarmonyHubController.Connecti onOpened(Object sender, ConnectionOpenedEventArgs e) at System.EventHandler`1.Invoke(Object sender, TEventArgs e) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    Mar-20 00:14:51 Error The Connection to Hub with ID 4d97790b8239ead10bfdadcd15511434c0744087 failed with message: One or more errors occurred.
    Mar-20 00:14:49 Error The Connection to Hub with ID 4d97790b8239ead10bfdadcd15511434c0744087 failed with stack trace: at HarmonyHub.Client.Send(String xml)
    Mar-20 00:14:49 Error The Connection to Hub with ID 4d97790b8239ead10bfdadcd15511434c0744087 failed with message: Object reference not set to an instance of an object.
    Mar-20 00:14:46 Error Posting back to plugin web page MeiHarmonyHub_Config: Object reference not set to an instance of an object.-> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
    Removed the plugin, I think totally.
    Rebooted HS.
    Whatever else I could think to do and can't get it to come back up.
    K.
